Discuss
Oven not heating to correct temperature
 in
We have a gas range that the oven will not come up to the correct temperature when it first is
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven not heating to correct temperature
  #1 (permalink)
Old 08-02-2013, 05:27 PM
Junior Member
horseisland is on a distinguished road
Default Oven not heating to correct temperature
Model Number: 31213XAW   Brand: Magic Chef   Age: More than 10 years
We have a gas range that the oven will not come up to the correct temperature when it first is turned on. The temperature can be set to 425 degrees and the temperature in the oven is 300 degrees according to the thermometer we have setting in the oven. If we want the oven to reach 375 degrees we set the thermostat at 450 degrees. The oven will reach 375 degrees, however, after about 1/2 hour it will reach 400 degrees.
We have replaced the thermostat control (twice) and the igniter (once). We do not know where to go from here.
Related Models
Magic Chef 31213XAW RANGE- F/S STD GAS
Magic Chef 3121SPA RANGE- F/S STD GAS
Magic Chef 3121SPW RANGE- F/S STD GAS
Magic Chef 3121SRA RANGE- F/S STD GAS
Magic Chef 3121SRW RANGE- F/S STD GAS
Magic Chef 3121STA RANGE- F/S STD GAS
Magic Chef 3121STW RANGE- F/S STD GAS
Magic Chef 3121WPA RANGE- F/S STD GAS
Magic Chef 3121WPV RANGE- F/S STD GAS
Magic Chef 3121WPW RANGE- F/S STD GAS
Magic Chef 3121WRA RANGE- F/S STD GAS
Magic Chef 3121WRV RANGE- F/S STD GAS
Magic Chef 3121WRW RANGE- F/S STD GAS
Magic Chef 3121WTA RANGE- F/S STD GAS
Magic Chef 3121WTV RANGE- F/S STD GAS
Magic Chef 3121WTW RANGE- F/S STD GAS
Magic Chef 3121XPA RANGE- F/S STD GAS
Magic Chef 3121XPS RANGE- F/S STD GAS
Magic Chef 3121XPW RANGE- F/S STD GAS
Magic Chef 3121XRA RANGE- F/S STD GAS
Magic Chef 3121XRA-UX RANGE- F/S STD GAS
Magic Chef 3121XRA-X RANGE- F/S STD GAS
Magic Chef 3121XRS RANGE- F/S STD GAS
Magic Chef 3121XRW RANGE- F/S STD GAS
Magic Chef 3121XRW-UX RANGE- F/S STD GAS
Magic Chef 3121XRW-X RANGE- F/S STD GAS
Magic Chef 3121XTA RANGE- F/S STD GAS
Magic Chef 3121XTS RANGE- F/S STD GAS
Magic Chef 3121XTW RANGE- F/S STD GAS
Magic Chef 3126SRA RANGE- F/S STD GAS
Magic Chef 3126SRW RANGE- F/S STD GAS
Magic Chef 3126STA RANGE- F/S STD GAS
Magic Chef 3126STW RANGE- F/S STD GAS
Magic Chef 3127STA RANGE- F/S STD GAS
Magic Chef 3127STW RANGE- F/S STD GAS
Magic Chef 3127WTA RANGE- F/S STD GAS
Magic Chef 3127WTV RANGE- F/S STD GAS
Magic Chef 3127WTW RANGE- F/S STD GAS
Magic Chef 3127XTA RANGE- F/S STD GAS
Magic Chef 3127XTW RANGE- F/S STD GAS
Magic Chef 31311SAA RANGE- F/S STD GAS
Magic Chef 31311SAW RANGE- F/S STD GAS
Magic Chef 31311WAA RANGE- F/S STD GAS
Magic Chef 31311WAW RANGE- F/S STD GAS
Magic Chef 31315VAM RANGE- F/S STD GAS
Magic Chef 31315VAV RANGE- F/S STD GAS
Magic Chef 31315VBM RANGE- F/S STD GAS
Magic Chef 31315VBV RANGE- F/S STD GAS
Magic Chef 31315WAM RANGE- F/S STD GAS
Magic Chef 31315WAV RANGE- F/S STD GAS
Magic Chef 31315XAA RANGE- F/S STD GAS
Magic Chef 31315XAW RANGE- F/S STD GAS
Magic Chef 31315XBA RANGE- F/S STD GAS
Magic Chef 31315XBW RANGE- F/S STD GAS
Magic Chef 3141XRA RANGE- F/S STD GAS
Magic Chef 3141XRW RANGE- F/S STD GAS
Magic Chef 3141XTA RANGE- F/S STD GAS
Magic Chef 3141XTW RANGE- F/S STD GAS
Magic Chef 3147XRA RANGE- F/S STD GAS
Magic Chef 3147XRA-X RANGE- F/S STD GAS
Magic Chef 3147XRW RANGE- F/S STD GAS
Magic Chef 3147XRW-X RANGE- F/S STD GAS
Magic Chef 3147XTA RANGE- F/S STD GAS
Magic Chef 3147XTW RANGE- F/S STD GAS
Magic Chef 3167VTV RANGE- F/S STD GAS
Magic Chef 3167VTW RANGE- F/S STD GAS
Magic Chef 3167VUV RANGE- F/S STD GAS
Magic Chef 3167XRA RANGE- F/S STD GAS
Magic Chef 3167XRA-X RANGE- F/S STD GAS
Magic Chef 3167XRW RANGE- F/S STD GAS
Magic Chef 3167XRW-X RANGE- F/S STD GAS
Magic Chef 3167XTA RANGE- F/S STD GAS
Magic Chef 3167XTA-X RANGE- F/S STD GAS
Magic Chef 3167XTW RANGE- F/S STD GAS
Magic Chef 3167XTW-X RANGE- F/S STD GAS
Magic Chef 3167XUA RANGE- F/S STD GAS
Magic Chef 3167XUA-X RANGE- F/S STD GAS
Magic Chef 3167XUW RANGE- F/S STD GAS
Magic Chef 3167XUW-X RANGE- F/S STD GAS
Magic Chef 3167XYA RANGE- F/S STD GAS
Magic Chef 3167XYW RANGE- F/S STD GAS
Magic Chef 3187VRA RANGE- F/S STD GAS
Magic Chef 3187VRV RANGE- F/S STD GAS
Magic Chef 3187VTA RANGE- F/S STD GAS
Magic Chef 3187VTV RANGE- F/S STD GAS
Magic Chef 3187VUA RANGE- F/S STD GAS
Magic Chef 3187VUV RANGE- F/S STD GAS
Magic Chef 3187XRA RANGE- F/S STD GAS
Magic Chef 3187XRW RANGE- F/S STD GAS
Magic Chef 3187XTA RANGE- F/S STD GAS
Magic Chef 3187XTW RANGE- F/S STD GAS
Magic Chef 3187XUA RANGE- F/S STD GAS
Magic Chef 3187XUW RANGE- F/S STD GAS
Magic Chef 31FA-1 RANGE- F/S STD GAS
Magic Chef 31FA-10 RANGE- F/S STD GAS
Magic Chef 31FA-10-FJ RANGE- F/S STD GAS
Magic Chef 31FA-10K RANGE- F/S STD GAS
Magic Chef 31FA-10K-49 RANGE- F/S STD GAS
Magic Chef 31FA-10K-FJ RANGE- F/S STD GAS
Magic Chef 31FA-10KLX-ON RANGE-F/S CONT CLEAN GAS
Magic Chef 31FA-10KLXS-ON RANGE-F/S CONT CLEAN GAS
Magic Chef 31FA-10KXS-ON RANGE- F/S STD GAS
Magic Chef 31FA-10XS-ON RANGE- F/S STD GAS
Magic Chef 31FA-11KLX-ON RANGE-F/S CONT CLEAN GAS
Magic Chef 31FA-11KW RANGE- F/S STD GAS
Magic Chef 31FA-11KX-ON RANGE- F/S STD GAS
Magic Chef 31FA-11KXS-ON RANGE- F/S STD GAS
Magic Chef 31FA-1K RANGE- F/S STD GAS
Magic Chef 31FA-1KLXS-ON RANGE-F/S CONT CLEAN GAS
Magic Chef 31FA-1KXS-ON RANGE- F/S STD GAS
Magic Chef 31FA-1XS-EL RANGE- F/S STD GAS
Magic Chef 31FA-1XS-ON RANGE- F/S STD GAS
Magic Chef 31FA-2KLX RANGE-F/S CONT CLEAN GAS
Magic Chef 31FA-2KLX-CI RANGE-F/S CONT CLEAN GAS
Magic Chef 31FA-2KLX-NK RANGE-F/S CONT CLEAN GAS
Magic Chef 31FA-2KLX-ON RANGE-F/S CONT CLEAN GAS
Magic Chef 31FA-2KW-30 RANGE- F/S STD GAS
Magic Chef 31FA-2KWZ RANGE- F/S STD GAS
Magic Chef 31FA-2KX RANGE- F/S STD GAS
Magic Chef 31FA-2KX-ON RANGE- F/S STD GAS
  #2 (permalink)
Old 08-02-2013, 08:02 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Some of the older units can run 75-100 degrees off naturally from the factory i've seen it a few times. Don't go by cheap thermometers from the store they can be off also. Also some units take awhile to get stable readings.......Should reach good temps after 10-15 minutes of starting unit. Make sure your thermostat probe is in the right spot where it was originally other then that i doubt you got 2 thermostats that were bad back to back. Might wanna check voltage to that thermostat? You may have a sticky safety valve perhaps or a faulty ignitor also? Get an amp clamp and test the ignitor when it's on it should be drawing at least 3 amps or more if it's not it a bad ignitor.....if the ignitor checks out good the safety valve should release gas to ignite in less then 2 minutes in most cases. Good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
convection oven not heating up to correct temperature cecelo Oven Repair (including Ranges and Cooktops) 1 01-18-2012 04:00 AM
GE JB910sk1ss oven not maintaining correct temperature sbrantley Oven Repair (including Ranges and Cooktops) 0 12-21-2011 12:04 PM
oven doesn't bake evenly temperature not correct Naomi J Berty Oven Repair (including Ranges and Cooktops) 1 10-08-2009 01:59 PM
Oven will not heat to correct temperature Luapam Oven Repair (including Ranges and Cooktops) 3 02-04-2009 02:15 PM
Oven not keeping correct Temperature Andrew Mail Oven Repair (including Ranges and Cooktops) 1 11-27-2007 03:34 PM
