I received an error code to replace the ui I replaced the part and now I have an error that says keypad disconnected. Is there anyway to test the ui to make sure it is ok before I spend another 200.00 for a new membrane. The reason I ask is the keypad works fine I can use all keys but after about 15 seconds the error pops up and shuts down oven. Code is f2eo
Mike
