Discuss
Posessed GE Cooktop Fan
 in
Late last evening, my GE Cooktop top fan started running without being turned on. I tried to turn the unit
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Posessed GE Cooktop Fan
  #1 (permalink)
Old 02-09-2008, 12:29 PM
tdale tdale is offline
Junior Member
tdale is on a distinguished road
Question Posessed GE Cooktop Fan
Model Number: JP389BD1BB   Brand: GE   Age: 5 - 10 years
Late last evening, my GE Cooktop top fan started running without being turned on. I tried to turn the unit off by turing the fan knob on top of the cooktop to an on position and back to the off position. This had no effect. I opened the doors to look underneath and heard a "crackingling" sound coming from the unit that houses the wires and relay. I then tried to shut the unit off again by lifting the knob from the top of the cooktop, replacing it and turning the knob to to all three on positions and back off again. This time the unit did turn off. I cut the power off to the unit.
Any ideas on what the problem may be?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-10-2008, 11:43 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
What happens if you restore the power?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-16-2008, 01:23 PM
Junior Member
Default
Thanks for the response. I finally restored the power today. The fan and all burners seem to be working properly. The crackling noise is no longer there. I was thinking if it happened again, I would replace the 5 prong relay switch and the fan switch.
thoughts?
Tom
  #4 (permalink)
Old 02-19-2008, 09:31 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Tom,
Guessing is not the best way to fix a problem. If it happened again I'll do my best to help with diagnosis.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Old Jenn-Air Cooktop fredringwald Oven Repair (including Ranges and Cooktops) 2 07-29-2008 11:36 AM
Kitchen Aid Cooktop wingnit Oven Repair (including Ranges and Cooktops) 4 02-01-2008 12:53 PM
G.E. cooktop Jeff Miller Oven Repair (including Ranges and Cooktops) 1 10-19-2007 05:13 PM
Thermador Cooktop Help jojo77 Oven Repair (including Ranges and Cooktops) 0 09-29-2007 01:04 PM
Cooktop lite Stu Mills Microwave Repair 0 08-24-2007 12:23 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
