I have a 4 burner surface stove located in an island. When I turn any of the four knobs, I hear the clicking and igniter sparks only at the front left burner. The other 3 igniters don't spark.
I have attached the left front burner with the good igniter to other 3 locations and at each location only that igniter sparks. So the 4 wires attached to the igniters are not shorted.
I'm planning to replace igniters in 3 of the non functioning burners with new igniters and check if that takes care of the problem.
Is my sprk module suspect? If yes, how do I go about replacing it? Any help would be appreciated.
