| » Maytag Gemini elements don't work |
Replacement parts for MAYTAG MER6755AAB | AppliancePartsPros.com Here is a tech sheet and manual http://www.servicematters.com/maytag...s/16023459.pdf http://www.servicematters.com/maytag...s/16023416.pdf I only see one thermal cutout and that is for the upper oven's broil element so that should not kill all elements. I am assuming that the stove top elements all run OK, if not you may have a power problem. Try turning the breaker off/on slowly a couple times. Try to run the diagnostics perhaps that will help narrow it down.
__________________
| Display Modes | |
| Maytag Gemini F1-1 Code | ijourneaux | Oven Repair (including Ranges and Cooktops) | 0 | 09-18-2009 12:26 PM |
| Maytag Gemini Dual Gas Oven Lower oven won't work | edlakes | Microwave Repair | 1 | 06-16-2009 07:48 PM |
| Maytag Gemini | grun | Oven Repair (including Ranges and Cooktops) | 0 | 06-08-2009 11:18 AM |
| Maytag Gemini | RAD | Oven Repair (including Ranges and Cooktops) | 1 | 12-18-2008 07:27 AM |
| Maytag Gemini both bake elements not working | trishtank | Oven Repair (including Ranges and Cooktops) | 3 | 11-02-2008 03:40 PM |
