Discuss
Kenmore Range Throwing F10-ERR Code
 in
This range is the black version 790.96599601, with the bridge unit on the left, a warming burner at the center
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Range Throwing F10-ERR Code
  #1 (permalink)
Old 07-29-2013, 11:04 AM
Junior Member
Mommeeu is on a distinguished road
Default Kenmore Range Throwing F10-ERR Code
Model Number: 95599   Brand: Kenmore   Age: 5 - 10 years
This range is the black version 790.96599601, with the bridge unit on the left, a warming burner at the center back, and two burners on the right.
In September 2012 I was convection baking at 400 degrees. When I attempted to change the temp to convection bake at 350 degrees, I immediately heard a crackling noise and saw a whisp of smoke rise from the back of the unit directly above the clock. I pressed "stop" and then heard a loud pop and smelled burning wires or some other kind of electrical odor. The unit worked normally until just a few days ago. I wanted to provide this background information in case the two events are related.
Recently, I was baking some Italian sausages at 350 degrees on a wire rack over a baking pan in the top third of the oven. I checked them and they were still whitish and baking slowly, so I went into the next room to work on the computer. Moments later, I heard sizzling and returned to the kitchen where I saw smoke coming out of the vent over the range top and an F10-ERR code. I opened the oven door to see blackend sausages and the top coil red hot. I pressed "stop" and removed the pan.
I rotated the sausages and put the pan back into the oven to try again at 350 degrees. Again, they blackened quickly, the F10-ERR code reappeared, and the upper coil was red hot. I pressed stop and also turned off the circuit breaker to the range as I do not wish it to burn my house down. I haven't used it since.
Do you have any ideas as to what might be the problem and what parts might be needed to fix it? We have the parts lists and exploded diagrams for this unit. My aircraft mechanic/auto mechanic/handyman husband has repaired my washer, dryer and dishwasher many times. He leaves refrigerators to the pros and may have to do the same for this, depending on your answer.
Thanks!!
Related Models
Admiral 958AF-CLW RANGE- D/I STD ELE
Admiral 958AF-CLZ RANGE- D/I STD ELE
Admiral 958AH-CZW RANGE- D/I STD ELE
Admiral 958AJ-ZW RANGE- D/I STD ELE
Admiral 958WF-CLW RANGE- D/I STD ELE
Admiral 958WF-CLZ RANGE- D/I STD ELE
Admiral 958WH-CZW RANGE- D/I STD ELE
Admiral 958WJ-ZW RANGE- D/I STD ELE
Kenmore 9607012190 GAS RANGE
Kenmore 9607012890 GAS RANGE
Kenmore 9607022190 Free Standing, Electric
Kenmore 9607022191 Free Standing, Electric
Kenmore 9607022890 Free Standing, Electric
Kenmore 9607022891 Free Standing, Electric
Kenmore 9607042190 GAS RANGE
Kenmore 9607042890 GAS RANGE
Kenmore 9607052190 Free Standing, Electric
Kenmore 9607052890 Free Standing, Electric
Kenmore 9607402190 FREE STAND GAS RANGE-PILOT
Kenmore 9607402890 FREE STAND GAS RANGE-PILOT
Kenmore 9607412190 Free Standing, Electric
Kenmore 9607412890 Free Standing, Electric
Kenmore 9609012190 20" & 24" ELECTRIC RANGE
Kenmore 9609012191 20" & 24" ELECTRIC RANGE
Kenmore 9609012192 20" & 24" ELECTRIC RANGE
Kenmore 9609012890 20" & 24" ELECTRIC RANGE
Kenmore 9609012891 20" & 24" ELECTRIC RANGE
Kenmore 9609012892 20" & 24" ELECTRIC RANGE
Kenmore 9609072190 20" & 24" ELECTRIC RANGE
Kenmore 9609072890 20" & 24" ELECTRIC RANGE
Magic Chef 9612WUV WALLOVEN- STD ELE
Magic Chef 9612XUB WALLOVEN- STD ELE
Magic Chef 9614XPB WALLOVEN- CONT CLEAN ELE
Magic Chef 9622XUB WALLOVEN- STD ELE
Magic Chef 9624XPB WALLOVEN- STD ELE
Amana 968.000 RANGE- S/C S/I DDRAFT GAS
Amana 968.010 RANGE- S/C S/I DDRAFT GAS
Admiral 968AF-C RANGE- S/C D/I ELE
Admiral 968AH-CHZW RANGE- S/C D/I ELE
Admiral 968WF-C RANGE- S/C D/I ELE
Admiral 968WH-CHZW RANGE- S/C D/I ELE
Amana 969.000 RANGE- S/C S/I DDRAFT GAS
Amana 969.001 RANGE- S/C S/I DDRAFT GAS
Amana 969.002 RANGE- S/C S/I DDRAFT GAS
Amana 969.003 RANGE- S/C S/I DDRAFT GAS
Magic Chef 96F-4CLX-19 WALLOVEN- CONT CLEAN ELE
Magic Chef 96FA-4CLW WALLOVEN- CONT CLEAN ELE
Magic Chef 96FA-4CLX WALLOVEN- CONT CLEAN ELE
Magic Chef 96FA-4CW WALLOVEN- STD ELE
Magic Chef 96FA-4CX WALLOVEN- STD ELE
Magic Chef 96FN-4CLW WALLOVEN- CONT CLEAN ELE
Magic Chef 96FN-4CLX WALLOVEN- CONT CLEAN ELE
Magic Chef 96FN-4CW WALLOVEN- STD ELE
Magic Chef 96FN-4CX WALLOVEN- STD ELE
Kenmore 970-445341 RANGE (CANADIAN)
Kenmore 970-598421 ELECTRIC RANGE
Kenmore 970-C40032-00 WASHER
Kenmore 970-C40042-00 WASHER
Kenmore 970-C40052-00 WASHER
Kenmore 970-C90052-00 DRYER
Kenmore 970-C90702-00 LAUNDRY CENTER
Kenmore 970-C90802-00 DRYER
Kenmore 970-C90862-00 LAUNDRY CENTER
Kenmore 970-C98902-00 LAUNDRY CENTER
Amana 970.000 RANGE- S/C S/I DDRAFT GAS
Amana 970.001 RANGE- S/C S/I DDRAFT GAS
Amana 970.002 RANGE- S/C S/I DDRAFT GAS
Kenmore 9703871220 SEARS-CANADA WASHER
Kenmore 9703880220 SEARS-CANADA WASHER
Kenmore 970C8003200 DRYER
Kenmore 970C8004200 DRYER
Kenmore 970C8005200 DRYER
Kenmore 970C9003200 DRYER
Kenmore 970C9004200 DRYER
Amana 975.000 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 97F-4EXWM9 WALLOVEN- S/C MWAVE ELE
Magic Chef 97F-4EXWW WALLOVEN- S/C ELE
Magic Chef 97FN-4EVWW WALLOVEN- S/C ELE
Magic Chef 97FN-4EXWW WALLOVEN- S/C ELE
Frigidaire 98-1348-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-1348-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-1348-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-1668-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-1668-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-1668-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-1668-00-03 Tap(v1) / Upright Freezer
Frigidaire 98-2188-00-00 Tap(v1) / Upright Freezer
Frigidaire 98-2188-00-01 Tap(v2) / Upright Freezer
Frigidaire 98-2188-00-02 Tap(v3) / Upright Freezer
Frigidaire 98-2188-00-03 Tap(v1) / Upright Freezer
Amana 980.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 980.001 RANGE- S/C S/I DDRAFT GAS
Amana 980.002 RANGE- S/C S/I DDRAFT GAS
Amana 980.003 MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 9814VPV WALLOVEN- S/C ELE
Magic Chef 9814XPB WALLOVEN- S/C ELE
Magic Chef 9815VUV WALLOVEN- S/C ELE
Magic Chef 9815XUB WALLOVEN- S/C ELE
Magic Chef 9824VPV WALLOVEN- S/C ELE
Magic Chef 9824XPB WALLOVEN- S/C ELE
Magic Chef 9825VUV WALLOVEN- S/C ELE
Magic Chef 9825XUB WALLOVEN- S/C ELE
Magic Chef 9834XPB WALLOVEN- S/C MWAVE ELE
Magic Chef 9835VVV WALLOVEN- S/C MWAVE ELE
Magic Chef 9835XUB WALLOVEN- S/C MWAVE ELE
Magic Chef 9835XVB WALLOVEN- S/C MWAVE ELE
Magic Chef 9844VPV WALLOVEN- S/C ELE
Magic Chef 9844XPB WALLOVEN- S/C ELE
Magic Chef 9845VUV WALLOVEN- S/C ELE
Magic Chef 9845VVV WALLOVEN- S/C ELE
Magic Chef 9845XUB WALLOVEN- S/C ELE
Magic Chef 9845XVB WALLOVEN- S/C ELE
Magic Chef 9850 MICROWAVE OVEN
Magic Chef 9854VPV WALLOVEN- S/C ELE
Magic Chef 9854XPB WALLOVEN- S/C ELE
Magic Chef 9855VUV WALLOVEN- S/C ELE
Magic Chef 9855VVV WALLOVEN- S/C ELE
Magic Chef 9855XUB WALLOVEN- S/C ELE
Magic Chef 9855XVB WALLOVEN- S/C ELE
Magic Chef 9864VPV WALLOVEN- S/C MWAVE ELE
  #2 (permalink)
Old 07-30-2013, 05:14 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Kenmore Range 79096599601 - AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodin...16441478en.pdf
If you go to the Sears parts site they should have actual part breakdown diagrams. Unfortunately they do not share these with other vendors.
F-10 is an overheat error.
Since the unit knew it was too hot the sensor is probably OK and it is the oven control board that is bad.
I would check the sensor just in case, see the tech sheet chart.
Part number: AP3965663
Click on the picture for more info.
__________________
  #3 (permalink)
Old 07-31-2013, 09:09 AM
Junior Member
Default
We have the exploded views and parts lists for the range. My husband will check the sensor first, as you recommend.
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer throwing ol code karpink Washer Repair 0 08-22-2012 02:12 PM
F10 code for a Kenmore Gas Range tgilham Oven Repair (including Ranges and Cooktops) 0 12-06-2009 05:14 PM
keeps throwing e1 code Chris and John Dryer Repair 2 09-08-2008 08:17 PM
Kenmore Oven throwing PF codes mgeubtn Oven Repair (including Ranges and Cooktops) 2 05-30-2008 07:58 PM
Kenmore Range error code F2-E0 mtfurtney Oven Repair (including Ranges and Cooktops) 1 01-28-2008 10:27 AM
