Discuss
Tappan oven is heating higher than set point
 in
Tappan model # 30-4952-00/02 is heating higher than set point causing burning of food. Is it the temp sensor? Thanks
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan oven is heating higher than set point
  #1 (permalink)
Old 07-26-2013, 07:45 PM
Junior Member
Burntfood is on a distinguished road
Default Tappan oven is heating higher than set point
Brand: Tappan   Age: More than 10 years
  #2 (permalink)
Old 07-26-2013, 08:07 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Heat up the oven to 350 pull the temp sensor connector off in the back and take an ohm reading on the probe you should have around 15-16 ohms if you dont then more then likely it's the temp sensor....
  #3 (permalink)
Old 07-27-2013, 08:52 AM
Junior Member
Default Tappan
Thanks.
A troubelshooting guide on another website stated that most temp sensors run 1000 to 1100 ohms at room temp.
The Tappan temp sensor showed 1108 ohms at room temp which would be in line (if the sensor is one the types listed on the troubleshooting site.) I heated it up with a lighter and it seemed to read linear with the heat added and removed. When I turn the oven on it just keeps heating so I cant set a temperature. Thats the problem with the range. The oven stays on constantly. It doesn't regulate. I feel it's the clock/control board.
  #4 (permalink)
Old 07-27-2013, 01:50 PM
Senior Member
Default
The trick with temp probes is that you have to test them at various tempatures to get an accurate diagnosis don't ever go by just room temp that's why i recommended 350 then test. Good luck yeah if it checks out at 350 i would possibly suspect main board as well but a bad temp sensor can make the oven stay on for a long time. Also take in mind some units will heat up to around 75 degrees over the tempature you set then about 10-15 minutes later it will gradually work it's way down to the temp. Also some units can be between 25-50 degrees off depending on how cheap the unit is and that's just normal unfortunately.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan oven/stove not heating up billyb133 Oven Repair (including Ranges and Cooktops) 1 11-25-2011 04:41 AM
oven temperature gets higher and higher susanshann Oven Repair (including Ranges and Cooktops) 2 02-13-2011 11:19 AM
Tappan Oven/Micro combo not heating Bonz22 Microwave Repair 0 10-06-2009 02:55 PM
Tappan Oven not heating evsolo Oven Repair (including Ranges and Cooktops) 1 04-23-2009 02:07 PM
Tappan Oven not heating - thermostat problem? Kathy B Oven Repair (including Ranges and Cooktops) 0 02-09-2009 02:25 PM
