This older Tappan, #30-4942-23/02 will heat up in the bake mode, overheat, then shut down. Problem is it shows no code/codes. After reading many posts with similar problems it seems to go back to the codes, of which there are none showing on my unit.
BTW, great forum, and I hope I have not violated any rules.
