control panel on wall oven not working. code that is displayed is E6 F2 and when i push the start button the display will come on. the oven will turn off by itself and the display will go blank. when i push the start button nothing happens.
The F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board.
