| » Maytag Range won't heat up |
Model Number: PER5750LAW Brand: Maytag Age: 5 - 10 years
I have a Maytag Performa stove. The other day, I went to cook in it and after 2 hours it had only made it to 185 degrees (I had set it for 350). I went to a parts store and they told me it was the thermostat, but then wanted to charge me $250 for the part. But then he said something about a control, which makes me think he actually meant (and was charging me for) the control board. I didn't purchase any parts from him but started doing some investigating. The digital display on the face of the stove works, so I'm not sure if I should actually replace the thermostat (for a mere $26, or the control board with is $140 (I found it MUCH cheaper online).
Related Models |
It's more likely the temperature sensor. Remove the back panel and look for the two-wire connector attached to the temp. sensor. Follow the wires up to the control board and disconnect there. A good sensor will have 1100-1300 ohms at room temperature. Much higher, or much lower: replace it.
__________________
Nemo malus felix |
Here is the manual and tech sheet for this unit
http://www.servicematters.com/maytag...s/16025644.pdf http://www.servicematters.com/maytag...s/16025650.pdf You may want to check that both elements are OK. Bake and broil elements are used during pre-heat so if one of them is gone it will take a long time to heat up.
__________________
Thanks! Is there a way to check the elements? I know the bottom element is consealed. I ordered a new heat sensor and replaced that today, but that wasn't the the problem. After replacing the sensor we turned the oven on and tried to preheat to 350. After 1 hour is was only up to 190.
| Display Modes | |
| Maytag Electric Range - Lights on but no heat | bunangst | Oven Repair (including Ranges and Cooktops) | 5 | 10-05-2009 07:49 AM |
| maytag gas range | jscope399 | Oven Repair (including Ranges and Cooktops) | 3 | 01-22-2009 06:23 AM |
| Maytag Gas Range-Oven will not heat up, but broiler works | jnastasiuk | Oven Repair (including Ranges and Cooktops) | 0 | 12-22-2008 05:39 PM |
| maytag range | bandman | Oven Repair (including Ranges and Cooktops) | 0 | 07-15-2008 10:42 AM |
| Range / Maytag | jonathan831 | Oven Repair (including Ranges and Cooktops) | 0 | 09-06-2007 06:38 PM |
