Discuss
6 burner gas cooktop
 in
The two middle burners on my 6 burner gas cooktop will not light. They click, but no spark and no
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » 6 burner gas cooktop
  #1 (permalink)
Old 07-22-2013, 09:13 PM
Junior Member
Penguin77323 is on a distinguished road
Default 6 burner gas cooktop
Model Number: Cgx456ub   Brand: Thermador   Age: More than 10 years
The two middle burners on my 6 burner gas cooktop will not light. They click, but no spark and no gas. Any idea what, if anything, I should try replacing? How simple might this be?
Related Models
Thermador CGX456UB
Thermador CGX456US
Thermador CGX456UW
Roper CGX635VW0 Ranges, Electric*
Roper CGX655VW0 GAS COOKTOP
Amana CH105 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH105T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH125 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH125T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH150 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH150T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH170 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH170T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Thermador CH30 CERAMIC COOKTOP
Thermador CH36 CERAMIC COOKTOP
Hardwick CH4-34A9 SURFACE UNIT- GAS
Hardwick CH4-34W9 SURFACE UNIT- GAS
Hardwick CH4-44A9 SURFACE UNIT- GAS
Hardwick CH4-44W9 SURFACE UNIT- GAS
Amana CH68 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CH68T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Hardwick CH7241819R WALLOVEN- CONT CLEAN GAS
Hardwick CH9616A79R RANGE- F/S STD GAS
Hardwick CH9616W79R RANGE- F/S STD GAS
Hardwick CH9626A79R RANGE- F/S STD GAS
Hardwick CH9626W79R RANGE- F/S STD GAS
Whirlpool CHA1300W0 Commercial Washers
Whirlpool CHCS51AE1 Freestanding Icemaker
Thermador CHCV30 CERAMIC COOKTOP
Thermador CHCV36 CERAMIC COOKTOP
Maytag CHE9000ACB RANGE- S/C S/I ELE
Maytag CHE9000BCB RANGE- S/C S/I ELE
Maytag CHE9000BCE RANGE- S/C S/I ELE
Maytag CHE9800ACB RANGE- S/C S/I ELE
Maytag CHE9800ACE RANGE- S/C S/I ELE
Maytag CHE9800BCB RANGE- S/C S/I ELE
Maytag CHE9800BCE RANGE- S/C S/I ELE
Maytag CHE9800BCM RANGE- S/C S/I ELE
Maytag CHE9830BCB RANGE- S/C S/I ELE
Maytag CHE9830BCE RANGE- S/C S/I ELE
Admiral CHEA700BCB RANGE- S/C S/I ELE
Admiral CHEA700BCE RANGE- S/C S/I ELE
Maytag CHG9800AAB RANGE- S/C S/I GAS
Maytag CHG9800AAE RANGE- S/C S/I GAS
Maytag CHG9800BAB RANGE- S/C S/I GAS
Maytag CHG9800BAE RANGE- S/C S/I GAS
Maytag CHG9800BAM RANGE- S/C S/I GAS
Maytag CHG9830BAB RANGE- S/C S/I GAS
Maytag CHG9830BAE RANGE- S/C S/I GAS
Admiral CHGA400BAB RANGE- S/C S/I GAS
Admiral CHGA400BAE RANGE- S/C S/I GAS
Amana CHP105 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP105T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP125 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP125T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP150 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP150T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP170 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP170T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP68 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP68T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Whirlpool CHW8990XW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ1 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900WQ0 COMMERCIAL AUTOMATIC WASHER
Amana CI7.7 FREEZER- CHEST
Amana CI8.8 FREEZER- CHEST
Amana CI8.8-C FREEZER- CHEST
Amana CIC-3 REF - TOP MOUNT
Amana CIC-4H REF - TOP MOUNT
Amana CIC3 MISC / ACCESSORY
Amana CIC4 MISC / ACCESSORY
Amana CIC4H MISC / ACCESSORY
Amana CIC4K MISC / ACCESSORY
Maytag CIKHTM-1 MISC / ACCESSORY
Maytag CIKHTM-1V MISC / ACCESSORY
Amana CIM105 REF - BOTTOM MOUNTS
Amana CIM105L REF - BOTTOM MOUNTS
Amana CIM125 REF - BOTTOM MOUNTS
Amana CIM125L REF - BOTTOM MOUNTS
Amana CIM98 REF - BOTTOM MOUNTS
Amana CIM98L REF - BOTTOM MOUNTS
Amana CIMR-19 REF - SXS/I&W
Amana CIMR-22 REF - SXS/I&W
Hardwick CJ1616A49R RANGE- F/S STD GAS
Hardwick CJ1616W49R RANGE- F/S STD GAS
Hardwick CJ1626A49R RANGE- F/S STD GAS
Hardwick CJ1626W49R RANGE- F/S STD GAS
Thermador CJ302UB
Thermador CJ302US
Thermador CJ302UW
Thermador CJ302ZS
Hardwick CJ7121809RC WALLOVEN- STD GAS
Hardwick CJ7122809RC WALLOVEN- STD GAS
Hardwick CJ7141809RC WALLOVEN- STD GAS
Hardwick CJ7141819DE WALLOVEN- STD GAS
Hardwick CJ7142809RC WALLOVEN- STD GAS
Hardwick CJ9641A590R RANGE- F/S STD GAS
Hardwick CJ9641W590R RANGE- F/S STD GAS
Amana CJW1008.A COMMERCIAL MICROWAVES
Amana CJW1008.B COMMERCIAL MICROWAVES
Amana CJW1008.Z COMMERCIAL MICROWAVES
Amana CJW1040.A COMMERCIAL MICROWAVES
Amana CJW1040.B COMMERCIAL MICROWAVES
Amana CJW1040.Z COMMERCIAL MICROWAVES
Gaggenau CK062-604
Gaggenau CK064-604
Gaggenau CK066-604
Gaggenau CK067-604
Gaggenau CK069-604
Gaggenau CK074-604
Gaggenau CK074-614
Gaggenau CK074-624
Gaggenau CK163-604
Gaggenau CK169-604
Gaggenau CK260-604
Gaggenau CK270-604
  #2 (permalink)
Old 07-22-2013, 09:47 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
So your saying no gas and no ignite? That's usually not the scenerio in most cases you should always have gas coming out no matter if the ignitor is working or not and is more of a mechanical problem as where the no ignite is an electrical problem in most cases. There's wiring that fits on top of the burner valve which may have an issue also if you don't have gas coming out i'm suspecting a bad burner valve for the no gas problem.
As far as the no spark issue which usually is separate there are things to check listed below.
1.Poke gas orfice down in unit with a safety pin to clean any carbon buildup in orfice
2.Clean any debris and take a wire brush to burner head and caps cleaning them of carbon and boil over and food buildup.................Most units have the ignitors all light at the same time or some have 2 spark modules. You could either have bad ignitors or food on the ignitors clean them with a piece of sandpaper gently and test again. If this doesn't solve your problem check to make sure your ignitor wires are connected good at the ignitor and spark module. Do not voltage test these with the switch trying to ignite it will blow your multimeter.
Last but not least if all these things fail you may also have a short in the ignitor wires but more then likely i'm suspecting a bad spark module since you have multiple burners not working should be located in the back of the unit or underneath the cooktop. Modules can be fairly cheap so if you see any burning on the exterior of the casing it should be replaced.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Gas Sealed Burner Cooktop Burner Problem Lemonpepper29 Oven Repair (including Ranges and Cooktops) 0 03-17-2012 04:33 PM
cooktop burner gets too hot greghb Oven Repair (including Ranges and Cooktops) 0 03-12-2012 06:53 PM
Cooktop Burner Control Light ON when Burner if OFF isimek@remedymd.com Oven Repair (including Ranges and Cooktops) 2 01-29-2011 11:48 PM
Cooktop burner not working-How do I know if its the burner or switch? joelake Oven Repair (including Ranges and Cooktops) 3 01-27-2011 08:13 AM
Burner not working on JEC9530ADB cooktop, is it burner or Switch? joelake Oven Repair (including Ranges and Cooktops) 0 12-29-2010 12:07 PM
