Door is stuck in closed position.I have removed range top and c/w visual inspection of latch.No defects .Removed door cover and found no defects.Door is stuck in top center.It has not been in the self cleaning operation.NEED HELP
Usually this will have a code that will pop up when your having problems.......You either have a door latch & lock issue..........a door switch is going bad and keeping the door locked or the main board is fouling out and not releasing the mechanism.
