Discuss
Power on - no heat from any element
 in
My convection oven wasn't heating up, so I followed several trouble shooting guides and found the heating coil to be
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Power on - no heat from any element
  #1 (permalink)
Old 07-21-2013, 06:40 PM
Junior Member
jd49er is on a distinguished road
Default Power on - no heat from any element
Model Number: C301   Brand: Thermador   Age: 1 - 5 years
My convection oven wasn't heating up, so I followed several trouble shooting guides and found the heating coil to be bad.
Also, it took the normal bake mode a much longer time than normal to achieve the desired heat. The broiler worked - no issues.
To address the convection oven issue, I replaced the heating coil and now have more problems.
Now, none of the heating elements turn on. There is power to the oven - the lights are on and one of the fans is running. I'm pretty sure I installed the convection coil properly. I did notice that the convection fan does not turn on. I'm assuming this is the reason the convection doesn't work. I have no idea why the bake or broil doesn't turn on.
Can all 3 issues be related to the same cause? Did I break something, or is it a simple "reset" of something??? Any advice would be immensely appreciated!
Related Models
Jenn-Air C301 SURFACE UNIT- DDRAFT ELE
Jenn-Air C301-C SURFACE UNIT- DDRAFT ELE
Thermador C301U BUILT-IN OVENS
Jenn-Air C302 SURFACE UNIT- DDRAFT ELE
Thermador C302U BUILT-IN OVENS
Roper C3057*0 Ranges, Electric*
Roper C3057X0 Ranges, Electric*
Jenn-Air C306 SURFACE UNIT- DDRAFT ELE
Jenn-Air C306-C SURFACE UNIT- DDRAFT ELE
Hoover C3077
Crosley C31000PAA RANGE- F/S STD GAS
Crosley C31000PAAD RANGE- F/S STD GAS
Crosley C31000PAT RANGE- F/S STD GAS
Crosley C31000PATP RANGE- F/S STD GAS
Crosley C31000PAW RANGE- F/S STD GAS
Crosley C31000PAWD RANGE- F/S STD GAS
Crosley C31000PAWP RANGE- F/S STD GAS
Roper C3107*0 Ranges, Electric*
Roper C3107L0 Ranges, Electric*
Crosley C31100PAA RANGE- F/S STD GAS
Crosley C31100PAV RANGE- F/S STD GAS
Crosley C31100SAA RANGE- F/S STD GAS
Crosley C31100SAAP RANGE- F/S STD GAS
Crosley C31100SAT RANGE- F/S STD GAS
Crosley C31100SATP RANGE- F/S STD GAS
Crosley C31100SAW RANGE- F/S STD GAS
Crosley C31100SAWP RANGE- F/S STD GAS
Crosley C31103SAA RANGE- F/S STD GAS
Crosley C31103SAT RANGE- F/S STD GAS
Crosley C31103SAW RANGE- F/S STD GAS
Crosley C31113WAA RANGE- F/S STD GAS
Crosley C31113WAAP RANGE- F/S STD GAS
Crosley C31113WAB RANGE- F/S STD GAS
Crosley C31113WAT RANGE- F/S STD GAS
Crosley C31113WATP RANGE- F/S STD GAS
Crosley C31113WAV RANGE- F/S STD GAS
Crosley C31113WAVP RANGE- F/S STD GAS
Crosley C31113XAA RANGE- F/S STD GAS
Crosley C31113XAT RANGE- F/S STD GAS
Crosley C31113XAW RANGE- F/S STD GAS
Crosley C31315VAM RANGE- F/S STD GAS
Crosley C31315VAV RANGE- F/S STD GAS
Crosley C31315VBM RANGE- F/S STD GAS
Crosley C31315VBQ RANGE- F/S STD GAS
Crosley C31315VBV RANGE- F/S STD GAS
Crosley C31315XBT RANGE- F/S STD GAS
Crosley C31315XBW RANGE- F/S STD GAS
Roper C3157*0 Ranges, Electric*
Roper C3157W0 Ranges, Electric*
Jenn-Air C316 SURFACE UNIT- DDRAFT ELE
Jenn-Air C316-C SURFACE UNIT- DDRAFT ELE
Jenn-Air C316W SURFACE UNIT- DDRAFT ELE
Jenn-Air C316W-C SURFACE UNIT- DDRAFT ELE
Roper C3257*0 Ranges, Electric*
Roper C3257W0 Ranges, Electric*
Roper C3357*0 Ranges, Electric*
Roper C3357W0 Ranges, Electric*
Whirlpool C3357^0
Roper C3408B0 Ranges, Electric*
Roper C3408B1 Ranges, Electric*
Roper C3408B2 Ranges, Electric*
Roper C3457*0 Ranges, Electric*
Roper C3457*1 Ranges, Electric*
Roper C3457X0 Ranges, Electric*
Roper C3457X1 Ranges, Electric*
Roper C3458*0 Ranges, Electric*
Roper C3458W0 Ranges, Electric*
Magic Chef C3510PVV RANGE- F/S STD ELE
Magic Chef C3521WRV RANGE- F/S STD ELE
Magic Chef C3521XRA RANGE- F/S STD ELE
Magic Chef C3521XRW RANGE- F/S STD ELE
Magic Chef C3523WVA RANGE- F/S STD ELE
Magic Chef C3523WVV RANGE- F/S STD ELE
Magic Chef C3542XRA RANGE- F/S STD ELE
Magic Chef C3542XRW RANGE- F/S STD ELE
Magic Chef C3581VRV RANGE- F/S STD ELE
Magic Chef C3581VUV RANGE- F/S STD ELE
Magic Chef C3581XRA RANGE- F/S STD ELE
Magic Chef C3581XRW RANGE- F/S STD ELE
Thermador C36 COOKTOP
Hoover C3820--- EXTR-W/FIX & ROT BRUSH,TEMPEST
Magic Chef C3842XRA RANGE- S/C F/S ELE
Magic Chef C3842XRW RANGE- S/C F/S ELE
Magic Chef C3862VYV RANGE- S/C F/S ELE
Magic Chef C3862XYB RANGE- S/C F/S ELE
Magic Chef C3868VYV RANGE- S/C F/S ELE
Magic Chef C3882VRV RANGE- S/C F/S ELE
Magic Chef C3882VVV RANGE- S/C F/S ELE
Magic Chef C3882XRA RANGE- S/C F/S ELE
Magic Chef C3882XRB RANGE- S/C F/S ELE
Magic Chef C3882XRW RANGE- S/C F/S ELE
Magic Chef C3882XVA RANGE- S/C F/S ELE
Magic Chef C3888VRV RANGE- S/C F/S ELE
Magic Chef C3888VVV RANGE- S/C F/S ELE
Magic Chef C3888XRA RANGE- S/C F/S ELE
Magic Chef C3888XRW RANGE- S/C F/S ELE
Magic Chef C3888XVA RANGE- S/C F/S ELE
Magic Chef C3888XVW RANGE- S/C F/S ELE
Hoover C4275--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C4277--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C4279--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5023--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5025--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5027--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5029--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5031--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5033--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5035--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5037--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5039--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5041--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C5122
Amana C52B ROOM AIR CONDITIONER
Maytag C5AALWH FREEZER- CHEST
Maytag C5ABLWH FREEZER- CHEST
Maytag C5H FREEZER- CHEST
Maytag C5J FREEZER- CHEST
Hoover C6075--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Hoover C6077--- COML-ACCESS,BURNISHER,FLOOR MCH,WET/DRY
Amana C6412301 MISC / ACCESSORY
  #2 (permalink)
Old 07-21-2013, 09:30 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
First off make sure you unplug your unit or turn off breaker before doing anything first. some models the convection fan can take almost up to 10 minutes to start before the fan starts blowing. If you connected the element you replaced properly it sounds like you may have an issue with the main board that is sending the power out. Only way to test that is too pull your elements out one by one and test be very very careful when you test this hot. Pull the connectors off the back of the element and make sure not to have them touch or fall back into back panel, YES EVEN NEUTRAL COLORS CAN BE HOT WHILE YOUR DOING THIS WITH THE CONTROL BOARD OFF EVEN AND IT CAN BE VERY DANGEROUS!. Once you've got the wires through a piece of cardboard or insulator so they don't touch the back of the unit take a voltage reading by turn the oven on and setting it to bake or broil whatever you're testing. Should have at least 120v or more present at the element hook ups. Also check the main board for loose connections for the wires leading down the unit to the elements. If you have no voltage at one of your elements during testing you either have a bad connection/a burned or shorted wire or a main board that is messing up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat ..no power to element terryg60 Dryer Repair 0 04-28-2012 05:45 PM
no power to heating element mikerun Oven Repair (including Ranges and Cooktops) 0 08-22-2009 07:57 AM
No Power going to motor or heat element Mary B Dryer Repair 3 01-15-2009 11:33 AM
No power to baking element Nickel125 Oven Repair (including Ranges and Cooktops) 0 10-25-2008 08:56 AM
Element won't heat up (20ohms on element and 120volts to the element)? puddlejumper123 Oven Repair (including Ranges and Cooktops) 0 04-22-2008 08:49 PM
