Discuss
frigidaire oven short at connecting block
 in
have a short at the far right connecting block, one of the 110 wires, the wire is burnt about one
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » frigidaire oven short at connecting block
  #1 (permalink)
Old 07-19-2013, 06:12 AM
Junior Member
dbruening is on a distinguished road
Default frigidaire oven short at connecting block
Model Number: gles388csa   Brand: Frigidaire   Age: 5 - 10 years
have a short at the far right connecting block, one of the 110 wires, the wire is burnt about one inch before the connector. After setting the the oven temperature it would run for about 10 seconds and then show a "PF" and then you could hear the short sputtering. Any ideas on how to troubleshoot and find the short as im assuming it was something away from the block?
Related Models
Frigidaire GLES388CSA Frigidaire/electric Range
Frigidaire GLES388CSB Frigidaire/electric Range
Frigidaire GLES388DBA Frigidaire/electric Range
Frigidaire GLES388DBB Frigidaire/electric Range
Frigidaire GLES388DQA Frigidaire/electric Range
Frigidaire GLES388DQB Frigidaire/electric Range
Frigidaire GLES388DSA Frigidaire/electric Range
Frigidaire GLES388DSB Frigidaire/electric Range
Frigidaire GLES389EBA Frigidaire/electric Range
Frigidaire GLES389EBB Frigidaire/electric Range
Frigidaire GLES389EBC Frigidaire/electric Range
Frigidaire GLES389EBD Frigidaire/electric Range
Frigidaire GLES389EBE Frigidaire/electric Range
Frigidaire GLES389EQA Frigidaire/electric Range
Frigidaire GLES389EQB Frigidaire/electric Range
Frigidaire GLES389EQC Frigidaire/electric Range
Frigidaire GLES389EQD Frigidaire/electric Range
Frigidaire GLES389EQE Frigidaire/electric Range
Frigidaire GLES389ESA Frigidaire/electric Range
Frigidaire GLES389ESB Frigidaire/electric Range
Frigidaire GLES389ESC Frigidaire/electric Range
Frigidaire GLES389ESD Frigidaire/electric Range
Frigidaire GLES389ESE Frigidaire/electric Range
Frigidaire GLES389FBA Frigidaire/electric Range
Frigidaire GLES389FBB Frigidaire/electric Range
Frigidaire GLES389FBC ELECTRIC RANGE
Frigidaire GLES389FBD ELECTRIC RANGE
Frigidaire GLES389FBE ELECTRIC RANGE
Frigidaire GLES389FBF ELECTRIC RANGE
Frigidaire GLES389FQA Frigidaire/electric Range
Frigidaire GLES389FQB Frigidaire/electric Range
Frigidaire GLES389FSA Frigidaire/electric Range
Frigidaire GLES389FSB Frigidaire/electric Range
Frigidaire GLES389FSC ELECTRIC RANGE
Frigidaire GLES389FSD ELECTRIC RANGE
Frigidaire GLES389FSE ELECTRIC RANGE
Frigidaire GLET1031CS0 Frigidaire/laundry Center
Frigidaire GLET1031FS0 Frigidaire/laundry Center
Frigidaire GLET1031FS1 LAUNDRY CENTER
Frigidaire GLET1031FS2 LAUNDRY CENTER
Frigidaire GLET1031FS4 LAUNDRY CENTER
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLET1142FS1 LAUNDRY CENTER
Frigidaire GLET1142FS2 LAUNDRY CENTER
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1326FW2 FREEZER
Frigidaire GLFC1326FW3 FREEZER
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC1526FW2 FREEZER
Frigidaire GLFC1526FW3 FREEZER
Frigidaire GLFC1526FW4 FREEZER
Frigidaire GLFC1526FW5 FREEZER
Frigidaire GLFC1526FW6 FREEZER
Frigidaire GLFC1526FW7 FREEZER
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2027FW4 FREEZER
Frigidaire GLFC2027FW5 FREEZER
Frigidaire GLFC2027FW6 FREEZER
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW10 FREEZER
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFC2528FW4 FREEZER
Frigidaire GLFC2528FW5 FREEZER
Frigidaire GLFC2528FW6 FREEZER
Frigidaire GLFC2528FW7 FREEZER
Frigidaire GLFC2528FW8 FREEZER
Frigidaire GLFC2528FW9 FREEZER
Frigidaire GLFH1467GW0 FREEZER
Frigidaire GLFH1467GW1 FREEZER
Frigidaire GLFH1767GW1 FREEZER
Frigidaire GLFH1779GW0 FREEZER
Frigidaire GLFH1779GW1 FREEZER
Frigidaire GLFH1779GW2 FREEZER
Frigidaire GLFH17F8HBA FREEZER
Frigidaire GLFH17F8HBB FREEZER
Frigidaire GLFH17F8HBC FREEZER
Frigidaire GLFH17F8HBD FREEZER
Frigidaire GLFH17F8HBF FREEZER
Frigidaire GLFH17F8HBG FREEZER
Frigidaire GLFH17F8HBH FREEZER
Frigidaire GLFH17F8HWA FREEZER
Frigidaire GLFH17F8HWB FREEZER
Frigidaire GLFH17F8HWC FREEZER
Frigidaire GLFH17F8HWD FREEZER
Frigidaire GLFH17F8HWE FREEZER
Frigidaire GLFH17F8HWF FREEZER
Frigidaire GLFH17F8HWG FRIGIDAIRE/FREEZER
Frigidaire GLFH17F8HWH FRIGIDAIRE/FREEZER
Frigidaire GLFH21F8HBA FREEZER
Frigidaire GLFH21F8HBB FREEZER
Frigidaire GLFH21F8HBC FREEZER
Frigidaire GLFH21F8HBD FREEZER
Frigidaire GLFH21F8HBE FREEZER
Frigidaire GLFH21F8HWA FREEZER
Frigidaire GLFH21F8HWB FREEZER
Frigidaire GLFH21F8HWC FREEZER
Frigidaire GLFH21F8HWD FREEZER
Frigidaire GLFH21F8HWE FREEZER
Frigidaire GLFH21F8HWG FREEZER
Frigidaire GLFN1326GW0 FREEZER
Frigidaire GLFN1326GW1 FREEZER
Frigidaire GLFN1326GW2 FREEZER
Frigidaire GLFN1326GW3 FREEZER
Frigidaire GLFU1467FW0 Frigidaire/freezer
Frigidaire GLFU1467FW1 FREEZER
Frigidaire GLFU1467FW2 FREEZER
Frigidaire GLFU1767FW2 Frigidaire/freezer
Frigidaire GLFU1767FW3 Frigidaire/freezer
Frigidaire GLFU1767FW4 Frigidaire/freezer
  #2 (permalink)
Old 07-20-2013, 05:18 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire GLES388CSA Range - AppliancePartsPros.com
Here is the wiring diagram.
http://manuals.frigidaire.com/prodin.../318045064.pdf
It will not be a short as a short would/should blow the circuit breaker in the electrical panel.
Is the sputtering coming from the connecting block?
I am assuming that the connecting block you refer to is the terminal strip (item 62 in the Body Parts section)
Odds are good that the problem is just at the terminal strip.
What can happen is that if there is a poor or loose connection when current passes through the connection it causes heat and perhaps pitting. This further degrades the connection causing more heat and so on and so on till the connection fails.
I would replace the terminal strip. Be sure to cut the bad wire back till you get to nice clean copper. Also clean all connections with fine emery cloth.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire oven will lose power on display and emit short buzz david112233 Oven Repair (including Ranges and Cooktops) 2 08-04-2014 05:53 AM
How to assemble the "short connecting rod" in the control box - Kitchenaid fridge kelhami Refrigerator & Freezer Repair 0 01-26-2012 10:19 AM
Frigidaire Control Panel Short rich129x2 Dishwasher Repair 0 07-25-2010 06:12 AM
Connecting Frigidaire Range Bridge Element John Minnoch Oven Repair (including Ranges and Cooktops) 0 08-21-2009 11:32 AM
connecting oven display rickkys Oven Repair (including Ranges and Cooktops) 0 07-20-2009 03:15 PM
