Discuss
Oven door power latch
 in
The top oven will not self clean , but the bottom oven will. The top latch is no op and the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven door power latch
  #1 (permalink)
Old 02-08-2008, 04:30 PM
Gordon Emberley Gordon Emberley is offline
Junior Member
Gordon Emberley is on a distinguished road
Default Oven door power latch
Model Number: SC272TS   Brand: Thermador   Age: 1 - 5 years
The top oven will not self clean , but the bottom oven will. The top latch is no op and the bottom one works...the lights /door "closed" switches both work.
All roads lead to the top power door latch. Any input about how to go about replacement will be appreciated as it will not come out through the front and I am guessing that the whole double oven must come out ...Like having to pull an engine to change a spark plug
Thanks Gordon Emberley
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-16-2008, 02:57 PM
GrandpaD GrandpaD is offline
Junior Member
GrandpaD is on a distinguished road
Default
I have similar problem. I just finished working with mine. Some screws will need drilling out because too tight. Tried WD40. Lock light does not come on and motor latch does not operate. Pulled oven halfway out. Not worth the trouble. Latch cost over $100. Will probably replace whole double over. Over 10 years old.
  #3 (permalink)
Old 02-16-2008, 04:28 PM
Junior Member
Default
I am also fed up with the (pricey) Termadore/Bosch run around, though now committed to having a service person comming for a "flat fee" of $178
to install the part that I already have. I tried to install myself and noticed right off that it was very different in size and configuration and would not fit the original mounting holes and also had to be completely rewired ad the new one has an extra switch...I'd call that a "manufacturer's defect", if a replacement part must be retrofitted and I never got so far as to find that the screws were heat welded to the frame as you did...seems to me that the "self cleaning" just cooks the motorized latch...Can't wait till the bottom oven also gives up....Kind regards, Gordon Emberley
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven & Broiler won't work..door latch lite on SunPilot Oven Repair (including Ranges and Cooktops) 0 02-08-2008 12:52 PM
door latch. 123dpw Microwave Repair 7 02-06-2008 06:14 AM
Oven Door Latch Locked W/O Door hseeger Oven Repair (including Ranges and Cooktops) 2 12-28-2007 12:42 PM
My Oven Door Latch Won't unlock so the door won"t close Victorine Ravenell Oven Repair (including Ranges and Cooktops) 1 11-14-2007 11:40 AM
Door latch broken/Door locked kitade Dishwasher Repair 2 10-23-2007 11:42 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
