z28931le
#1 Posted : Saturday, July 13, 2013 9:12:06 AM(UTC)
z28931le
I have 2005 Maytag MEW5627DDB (SN-12958319GR) and in the past year after short power outage the double oven touchpad didn't work right. After resetting breaker a couple of times, everything worked right again. But now, after outage, everything works OK except the bake touch-button (upper and lower oven) does nothing. When I reset breaker, Error Code E01 shows up for about 5 seconds before the clock time (blinking for reset time). I have unplugged connectors from control board to reseat them (couldn't do the two ribbon cables because of access problems). Same problem still exist (no BAKE function). One weird think, if I push the two BAKE buttons (upper and lower oven) simultaneously, the KEEP WARM function lights up??? Can anyone help to at least determine if its the Control Circuit Board or the Control TouchPad with Clock. Thanks for any help.
patphillippi
#2 Posted : Sunday, January 12, 2014 5:16:27 PM(UTC)
patphillippi
Did you ever resolve the issue?
