My Stove burners and broiler comes on with no problem. But when I turn on the oven it only gets warm and never reaches the desired temperature. The control buttons for stove work fine as well everything lights up as it suppose to.
it is most likely a bad bake element. when you turn the over on bake, the broil element comes on either on half power or cycles intermittently. that is where you are getting your heat in the oven. it will heat but not likely to reach temp. check bake element for burn marks, or if you have a meter check the element for continuity. set meter on lowest scale, you should read about 15 to 30 ohms.
