Discuss
Old GE Double Oven wont self clean
 in
My Mother's in-wall double oven won't self clean on the top oven (the bottom oven works fine). The lower oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Old GE Double Oven wont self clean
  #1 (permalink)
Old 07-08-2013, 10:25 AM
Junior Member
tarbetb is on a distinguished road
Default Old GE Double Oven wont self clean
Model Number: JKP36G0D2BG   Brand: GE   Age: More than 10 years
My Mother's in-wall double oven won't self clean on the top oven (the bottom oven works fine). The lower oven works fine. You press a latch release button on the display and slide a lock to lock the door. Then you have to press that latch release button when the cleaning is done to unlock the latch. You set the Temperature and setting dial both to "Clean" and make sure the start timer is set to current time and the stop timer is set for 2-3 hours from the current time. The red light above the Temperature knob illuminates as does the "Clean" light and the lower oven heats up and cleans.
The upper oven doesn't light up the "Clean" light when you go through that same procedure. The latch on the upper oven will come unlatched without pressing the latch release button, so I am suspect of something not working correctly in the switch on that upper latch. I've had the display panel loose and there are two items that look like switches mounted on the latch mechanism. The switch closest to the front is closed (continuity across it) when the latch is not locked and then is open when the latch locks. I also discovered that when the lower oven is in a cleaning and I lock the upper oven latch, the "Clean" light goes out and neither oven will clean. Do you think one of the switches on the upper latch is bad or could it be Temperature or Setting knob for the upper oven?
Related Models
General Electric JKP37G*L1 Electric range
General Electric JKP37G*L1WG GE BUILT-IN OVENS, CONVE
General Electric JKP38G*J1 Electric range
General Electric JKP38G*J2 Electric range
General Electric JKP38G*J3 Electric range
General Electric JKP38G*J4 Electric range
General Electric JKP38G*J5 Electric range
General Electric JKP38G*J6 Electric range
General Electric JKP38G0J3 ELECTRIC BUILT-IN OVEN
General Electric JKP38GJ4 ELECTRIC WALL OVEN
General Electric JKP38GJ5 ELECTRIC WALL OVEN
General Electric JKP38GJ6 ELECTRIC WALL OVEN
General Electric JKP39G*K1 Electric range
General Electric JKP39G*K2 Electric range
General Electric JKP39G*K3 Electric range
General Electric JKP39G*K4 Electric range
General Electric JKP40G*K1 Electric range
General Electric JKP40G*K2 Electric range
General Electric JKP40G*K3 Electric range
General Electric JKP40G*K4 Electric range
General Electric JKP44GP1 Electric range
General Electric JKP44GP2BG Electric range
General Electric JKP44GP3BG Electric range
General Electric JKP44GP4BG Electric range
General Electric JKP44GT1BB Electric range
General Electric JKP44GT2BB Electric range
General Electric JKP44GV1BB Electric range
General Electric JKP45BA1BB Electric range
General Electric JKP45BA2BB Electric range
General Electric JKP45BA3BB Electric range
General Electric JKP45BD1BB Electric range
General Electric JKP45BW1BB Electric range
General Electric JKP45BW2BB Electric range
General Electric JKP45CD1CC Electric range
General Electric JKP45WA1WW Electric range
General Electric JKP45WA2WW Electric range
General Electric JKP45WA3WW Electric range
General Electric JKP45WD1WW Electric range
General Electric JKP45WP1 Electric range
General Electric JKP45WP2WG Electric range
General Electric JKP45WP3WG Electric range
General Electric JKP45WT1WW Electric range
General Electric JKP45WT2WW Electric range
General Electric JKP45WV1WW Electric range
General Electric JKP45WW1WW Electric range
General Electric JKP45WW2WW Electric range
General Electric JKP46G*K1 Electric range
General Electric JKP46G*K2 Electric range
General Electric JKP46G*K3 Electric range
General Electric JKP46G*K4 Electric range
General Electric JKP47G*K1 Electric range
General Electric JKP47G*K2 Electric range
General Electric JKP47G*K3 Electric range
General Electric JKP47G*K4 Electric range
General Electric JKP47G*K5 Electric range
General Electric JKP48BF1BB Electric range
General Electric JKP48BF2BB Electric range
General Electric JKP48BF3BB Electric range
General Electric JKP48BF4BB Electric range
General Electric JKP48BF5BB Electric range
General Electric JKP48BF6BB Electric range
General Electric JKP48CF1CC Electric range
General Electric JKP48CF2CC Electric range
General Electric JKP48CF3CC Electric range
General Electric JKP48CF4CC Electric range
General Electric JKP48CF5CC Electric range
General Electric JKP48CF6CC Electric range
General Electric JKP48G*K1 Electric range
General Electric JKP48G*K2 Electric range
General Electric JKP48G*K3 Electric range
General Electric JKP48G*K4 Electric range
General Electric JKP48G*K5 Electric range
General Electric JKP48WF1WW Electric range
General Electric JKP48WF2WW Electric range
General Electric JKP48WF3WW Electric range
General Electric JKP48WF4WW Electric range
General Electric JKP48WF5WW Electric range
General Electric JKP48WF6WW Electric range
General Electric JKP50SH1SS Electric range
General Electric JKP50SH2SS Electric range
General Electric JKP50SH3SS Electric range
General Electric JKP50SH4SS Electric range
General Electric JKP50SH5SS Electric range
General Electric JKP50SH6SS Electric range
General Electric JKP54GP1BG Electric range
General Electric JKP54GP2BG Electric range
General Electric JKP54GP3BG Electric range
General Electric JKP54GP4BG Electric range
General Electric JKP54GT1BB Electric range
General Electric JKP54GT2BB Electric range
General Electric JKP54GV1BB Electric range
General Electric JKP55BM1BB ELECTRIC WALL OVEN
General Electric JKP55BM2BB ELECTRIC WALL OVEN
General Electric JKP55BM3BB ELECTRIC WALL OVEN
General Electric JKP55CM1CC ELECTRIC WALL OVEN
General Electric JKP55CM2CC ELECTRIC WALL OVEN
General Electric JKP55DP1BB ELECTRIC WALL OVEN
General Electric JKP55DP1CC ELECTRIC WALL OVEN
General Electric JKP55DP1WW ELECTRIC WALL OVEN
General Electric JKP55DP2BB ELECTRIC WALL OVEN
General Electric JKP55DP2CC ELECTRIC WALL OVEN
General Electric JKP55DP2WW ELECTRIC WALL OVEN
General Electric JKP55DP3BB ELECTRIC OVEN
General Electric JKP55DP3CC ELECTRIC OVEN
General Electric JKP55DP3WW ELECTRIC OVEN
General Electric JKP55G*01 Electric range
General Electric JKP55G*D1 Electric range
General Electric JKP55SM1SS ELECTRIC WALL OVEN
General Electric JKP55SM2SS ELECTRIC WALL OVEN
General Electric JKP55SM3SS ELECTRIC WALL OVEN
General Electric JKP55SP1SS ELECTRIC WALL OVEN
General Electric JKP55SP2SS ELECTRIC WALL OVEN
General Electric JKP55SP3SS ELECTRIC OVEN
General Electric JKP55WM1WW ELECTRIC WALL OVEN
General Electric JKP55WM2WW ELECTRIC WALL OVEN
General Electric JKP55WP1WG Electric range
General Electric JKP55WP2WG Electric range
General Electric JKP55WP3WG Electric range
General Electric JKP55WT1WW Electric range
General Electric JKP55WT2WW Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool double oven went blank after self clean Jm91rs Oven Repair (including Ranges and Cooktops) 21 07-27-2013 12:35 PM
Thermador Double Oven Self Clean canalking Oven Repair (including Ranges and Cooktops) 1 01-28-2012 08:56 AM
27" electric double oven self clean w/erc111 & upper convection oven sksmith Oven Repair (including Ranges and Cooktops) 0 12-22-2010 06:08 PM
Elec. double oven wont work after self clean jdnr144 Oven Repair (including Ranges and Cooktops) 0 03-17-2010 07:32 AM
Thermador Double Oven No self clean top JWLloyd Oven Repair (including Ranges and Cooktops) 3 05-11-2009 03:18 PM
