Discuss
Electric Jenn-Air Range Control Panel
 in
I have a Jenn-Air range JES8860CCB00 and the buttons are out again. The control piece with the clock was replaced
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric Jenn-Air Range Control Panel
  #1 (permalink)
Old 07-07-2013, 12:02 PM
Junior Member
LAWood is on a distinguished road
Default Electric Jenn-Air Range Control Panel
Model Number: JES8860CCB00   Brand: Jenn-Air   Age: 1 - 5 years
I have a Jenn-Air range JES8860CCB00 and the buttons are out again. The control piece with the clock was replaced twice and the entire front control piece (black part where knobs fit in with control behind) replaced once under warrantee when I first purchased the range. About six months ago some of the buttons failed again and I read on this site that based on those that failed it was likely one of the (lines in the ribbon?) so asked my son who is an mechanical engineer to open it up, pull the ribbon and clean it with an eraser. He said nothing was wrong with the ribbon and connections but laughed when he saw that the heat shield in the range (between the heat of the oven and the control panel) seemed to consist of a single piece of corrugated cardboard. Since the oven button worked I have lived with it since but yesterday the oven, and all other buttons have failed. The clock is still working as are the stove elements. Does anyone know if there has been a recall on this range? Surely it can't again be the control panel with less than three years since purchase. There must be some larger issue that is causing this failure. Any suggestions are welcomed before I throw more money at this expensive range.
Thank-you very much for your assistance.
Related Models
Maytag JES8860CCB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CCS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CCS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES8860CCS02 30" SLIDE-IN ELECTRIC RANGE
Maytag JES8860CCW00 30" SLIDE-IN ELECTRIC RANGE
General Electric JES922T01 Counter top microwave
General Electric JES922T02 Counter top microwave
General Electric JES927TWH01 Counter top microwave
General Electric JES933BW01 Counter top microwave
General Electric JES933PN01 Counter top microwave
General Electric JES933PN02 SAMSUNG .9 MICROWAVE
General Electric JES933PN03 SAMSUNG .9 MICROWAVE
General Electric JES933WN01 Counter top microwave
General Electric JES933WN02 SAMSUNG .9 MICROWAVE
General Electric JES933WN03 SAMSUNG .9 MICROWAVE
General Electric JES933WW01 Counter top microwave
General Electric JES933WW02 Counter top microwave
General Electric JES934WY01 Counter top microwave
General Electric JES939WD001 Counter top microwave
General Electric JES939WD002 Counter top microwave
Jenn-Air JES9750AAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9750AAS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9750AAW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9750BAB RANGE- S/C S/I DDRAFT ELE
Maytag JES9750BAB17 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9750BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9750BAS18 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9750BAW RANGE- S/C S/I DDRAFT ELE
Maytag JES9750BAW17 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9750CAS02 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9750CAW00 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9800AAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAQ RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800AAW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800ACW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAF RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9800BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9800BAS18 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAB17 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAF00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAF17 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAR00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9800CAS01 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860AAB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860AAS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860AAW RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860ACB RANGE- S/C S/I ELE
Jenn-Air JES9860ACS RANGE- S/C S/I ELE
Jenn-Air JES9860ACW RANGE- S/C S/I ELE
Jenn-Air JES9860BAB RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAB18 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAS19 SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BAW RANGE- S/C S/I DDRAFT ELE
Maytag JES9860BAW18 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9860BCB RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860BCS RANGE- S/C S/I DDRAFT ELE
Jenn-Air JES9860BCW RANGE- S/C S/I DDRAFT ELE
Maytag JES9860CAB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CAW00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9860CCW00 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAB RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAB19 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAF RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAF18 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900BAF19 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BAS RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BAS20 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCB RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCB20 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCS RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCS21 30" SLIDE-IN ELECTRIC RANGE
Jenn-Air JES9900BCW RANGE- S/C S/I DDRAFT ELE
Maytag JES9900BCW20 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCB00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCS00 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCS01 30" SLIDE-IN ELECTRIC RANGE
Maytag JES9900CCW00 30" SLIDE-IN ELECTRIC RANGE
General Electric JET1050A1 Counter top microwave
General Electric JET1050Y4 Counter top microwave
General Electric JET1060A1 Counter top microwave
General Electric JET1060A2 Counter top microwave
General Electric JET107001 Counter top microwave
General Electric JET108001 Counter top microwave
General Electric JET1110Y4 Counter top microwave
General Electric JET1120A1 Counter top microwave
General Electric JET1120A2 Counter top microwave
General Electric JET114001 Counter top microwave
General Electric JET1300A1 Counter top microwave
General Electric JET200001 Counter top microwave
General Electric JET200002 Counter top microwave
General Electric JET200003 Counter top microwave
General Electric JET200004 Counter top microwave
General Electric JET202001 Counter top microwave
General Electric JET2020D1 Counter top microwave
General Electric JET2020D2 Counter top microwave
General Electric JET2020D3 Counter top microwave
General Electric JET2020D4 Counter top microwave
General Electric JET203001 Counter top microwave
General Electric JET203002 Counter top microwave
General Electric JET203003 Counter top microwave
General Electric JET204001 Counter top microwave
General Electric JET208001 Counter top microwave
General Electric JET208002 Counter top microwave
General Electric JET208003 Counter top microwave
General Electric JET209001 Counter top microwave
  #2 (permalink)
Old 07-07-2013, 02:05 PM
Senior Member
scott5495 is on a distinguished road
Default jenn air
most likely the touch panel is out again. the only real test for the panel is to hold the keypad in and then measure ohms at ribbon connector. jenn air has had a lot of trouble with these keypads but I am unaware of a recall. it does not hurt to give jenn air consumer relations a call and ask if they will help with part cost. BE NICE! they respond better. on touch pads, they are really membrane switches. never clean any kind of touch pad with any cleaner, such as windex etc. only soap and water. the chemicals in cleaners can penetrate the membrane and take out the touch panel. only exception is keypads that are glass
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
control-electric Jenn-Air dual fuel range Alison Lynch Oven Repair (including Ranges and Cooktops) 0 01-28-2012 02:04 PM
Whirlpool Electric Range Control Panel Does Not Work winzy Oven Repair (including Ranges and Cooktops) 0 08-21-2011 09:16 PM
Replaced Control Panel on Whirlpool Electric Range but there is nothing lheidema Oven Repair (including Ranges and Cooktops) 4 06-24-2011 08:34 AM
Jenn-air Electric Range Key Panel rtaaron Oven Repair (including Ranges and Cooktops) 0 03-24-2011 12:19 PM
Maytag Electric Range Control Panel Dim Chryslerpetz Oven Repair (including Ranges and Cooktops) 0 12-26-2007 06:52 PM
