Discuss
They Are Not Marked! Which Connector Is Which On The Maytag Replacement Thermostat
 in
Can someone help ? I am replacing a old Gaffers & Sattler gas oven thermostat (part #993-453) with the recommended
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » They Are Not Marked! Which Connector Is Which On The Maytag Replacement Thermostat
  #1 (permalink)
Old 02-08-2008, 03:39 PM
Rock Rock is offline
Junior Member
Rock is on a distinguished road
Question They Are Not Marked! Which Connector Is Which On The Maytag Replacement Thermostat
Model Number: Part #AP379254   Brand: -other-   Age: More than 10 years
Can someone help ? I am replacing a old Gaffers & Sattler gas oven thermostat (part #993-453) with the recommended Maytag replacement part Manufacturer's # 7404P066-60 (part # AP379254) and have received the replacement part but, the two terminals on the replacement part are not marked. The old part (#993-453) is marked with a BKE for one terminal and L1 for the other terminal. Since the replacement part is totally different in looks than the original part and the terminals not marked I am lost as to reconnecting the two oven wires to the two UNMARKED terminals on the replacement part (if connected wrong and blows replacement part, warranty is no good). Again, the replacement part is somewhat different in looks, smaller and both UNMARKED terminals protrude in a different direction. None of this is a problem as long as I can get the oven wires connected to the replacement part thermostat terminals correctly. Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-13-2008, 03:46 PM
Junior Member
Default No need to be marked.
Because it is a gas oven it does not matter how the oven wires are connected to the terminals. It is now connected and, up and running.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer transmission replacement Billwhite Washer Repair 2 01-30-2008 04:49 AM
Maytag Performa washer snubber replacement richappy General Talk 0 01-06-2008 06:43 AM
water tube connector justone Refrigerator & Freezer Repair 1 12-04-2007 12:22 PM
new thermostat replacement deronsherry Oven Repair (including Ranges and Cooktops) 0 10-05-2007 07:41 AM
Maytag control board replacement catsun54 Refrigerator & Freezer Repair 1 09-29-2007 03:55 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
