Handle end cap broke as a result of a sticky hinge. Can remove door to replace but would like to also replace hinges. Is this a job for a rank amateur? Is there a manual available to show part #'s and steps to replace the hinges?:confused: Don't want to waste the money for end cap if I can't replace the hinges! Help! thanks
