Discuss
control panel
 in
Bottom element only worked part time. Broil element works fine. Replace bottom element. No change. If it is in the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » control panel
  #1 (permalink)
Old 07-02-2013, 11:38 AM
Junior Member
xtrmn8r is on a distinguished road
Default control panel
Model Number: PLEBSFCA   Brand: Frigidaire   Age: 5 - 10 years
Bottom element only worked part time. Broil element works fine. Replace bottom element. No change. If it is in the control panel, do i need the whole panel or just the component behind the panel. Any help appreciated..Model # correction...PLEB30S9FCA
Related Models
Frigidaire PLEC30S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECC Frigidaire/cooktop
Frigidaire PLEC36S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECC Frigidaire/cooktop
Frigidaire PLEF398ACA Frigidaire/range
Frigidaire PLEF398ACB Frigidaire/electric Range
Frigidaire PLEF398ACC Frigidaire/electric Range
Frigidaire PLEF398CCA Frigidaire/electric Range
Frigidaire PLEF398CCB Frigidaire/electric Range
Frigidaire PLEF398CCC Frigidaire/electric Range
Frigidaire PLEF398CCD Frigidaire/electric Range
Frigidaire PLEF398CCE Frigidaire/electric Range
Frigidaire PLEF398DCA Frigidaire/electric Range
Frigidaire PLEF398DCB Frigidaire/electric Range
Frigidaire PLEF398DCC Frigidaire/electric Range
Frigidaire PLEF398DCD Frigidaire/range
Frigidaire PLEF398DCE Frigidaire/range
Frigidaire PLEF398DCH Frigidaire/range
Frigidaire PLEF398DCJ Frigidaire/electric Range
Frigidaire PLEF489ACA Frigidaire/electric Range
Frigidaire PLEF489ACB Frigidaire/electric Range
Frigidaire PLEF489ACC Frigidaire/electric Range
Frigidaire PLEF489ACD Frigidaire/electric Range
Frigidaire PLEF489CCA Frigidaire/electric Range
Frigidaire PLEF489CCB Frigidaire/electric Range
Frigidaire PLEF489CCC Frigidaire/electric Range
Frigidaire PLEF489CCD Frigidaire/electric Range
Frigidaire PLEF489CCE Frigidaire/electric Range
Frigidaire PLEF489CCF Frigidaire/electric Range
Frigidaire PLEF489CCG Frigidaire/electric Range
Frigidaire PLEF489CCH ELECTRIC RANGE
Frigidaire PLEF489GCA ELECTRIC RANGE
Frigidaire PLEFM399DCA Frigidaire/electric Range
Frigidaire PLEFM399DCB Frigidaire/electric Range
Frigidaire PLEFM399DCC Frigidaire/electric Range
Frigidaire PLEFM399DCD Frigidaire/range
Frigidaire PLEFMZ99ECA Frigidaire/range
Frigidaire PLEFMZ99ECC Frigidaire/range
Frigidaire PLEFMZ99ECE Frigidaire/electric Range
Frigidaire PLEFMZ99ECF Frigidaire/electric Range
Frigidaire PLEFMZ99ECG Frigidaire/range
Frigidaire PLEFMZ99ECJ Frigidaire/electric Range
Frigidaire PLEFMZ99ECK Frigidaire/range
Frigidaire PLEFMZ99ECM ELECTRIC RANGE
Frigidaire PLEFMZ99ECN ELECTRIC RANGE
Frigidaire PLEFMZ99GCA ELECTRIC RANGE
Frigidaire PLEFMZ99GCB ELECTRIC RANGE
Frigidaire PLEFMZ99GCC ELECTRIC RANGE
Frigidaire PLEFMZ99GCD ELECTRIC RANGE
Frigidaire PLEFMZ99GCE ELECTRIC RANGE
Frigidaire PLEFZ398ECA Frigidaire/electric Range
Frigidaire PLEFZ398ECB Frigidaire/electric Range
Frigidaire PLEFZ398ECC Frigidaire/range
Frigidaire PLEFZ398ECD Frigidaire/electric Range
Frigidaire PLEFZ398ECE Frigidaire/range
Frigidaire PLEFZ398ECF Frigidaire/range
Frigidaire PLEFZ398GCA ELECTRIC RANGE
Frigidaire PLEFZ398GCB ELECTRIC RANGE
Frigidaire PLEFZ398GCC ELECTRIC RANGE
Frigidaire PLES389ACA Frigidaire/electric Range
Frigidaire PLES389ACB Frigidaire/electric Range
Frigidaire PLES389ACC Frigidaire/electric Range
Frigidaire PLES389ACD Frigidaire/electric Range
Frigidaire PLES389CCA Frigidaire/electric Range
Frigidaire PLES389CCB Frigidaire/electric Range
Frigidaire PLES389CCC Frigidaire/electric Range
Frigidaire PLES389DCA Frigidaire/electric Range
Frigidaire PLES389DCB Frigidaire/electric Range
Frigidaire PLES389DCC Frigidaire/electric Range
Frigidaire PLES389DCD Frigidaire/electric Range
Frigidaire PLES389DCE Frigidaire/electric Range
Frigidaire PLES389ECB Frigidaire/electric Range
Frigidaire PLES389ECC Frigidaire/electric Range
Frigidaire PLES389ECD Frigidaire/electric Range
Frigidaire PLES389ECE Frigidaire/range
Frigidaire PLES389ECF Frigidaire/electric Range
Frigidaire PLES389ECG Frigidaire/electric Range
Frigidaire PLES389ECH Frigidaire/electric Range
Frigidaire PLES389ECI ELECTRIC RANGE
Frigidaire PLES389ECJ ELECTRIC RANGE
Frigidaire PLES399ECB Frigidaire/electric Range
Frigidaire PLES399ECC Frigidaire/electric Range
Frigidaire PLES399ECD Frigidaire/range
Frigidaire PLES399ECE Frigidaire/electric Range
Frigidaire PLES399ECF Frigidaire/electric Range
Frigidaire PLES399ECG Frigidaire/electric Range
Frigidaire PLES399ECH ELECTRIC RANGE
Frigidaire PLES399ECI ELECTRIC RANGE
Frigidaire PLEW27S3ECA Frigidaire/warmer Drawer
Frigidaire PLEW27S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3ACA Frigidaire/warmer Drawer
Frigidaire PLEW30S3CCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCB Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCB Frigidaire/warmer Drawer
Frigidaire PLFH1779GS0 FREEZER
Frigidaire PLFH1779GS1 FREEZER
Frigidaire PLFH1779GS2 FREEZER
Frigidaire PLFH1779GS3 FREEZER
Frigidaire PLFU1777DS0 Frigidaire/freezer
Frigidaire PLFU1777DS1 Frigidaire/freezer
Frigidaire PLFU1777DS2 Frigidaire/freezer
Frigidaire PLFU1778ES0 Frigidaire/freezer
Frigidaire PLFU1778ES1 Frigidaire/freezer
Frigidaire PLFU1778ES2 Frigidaire/freezer
Frigidaire PLFU1778ES3 FREEZER
Frigidaire PLFU1778ES4 FREEZER
Frigidaire PLFU1778ES5 FREEZER
Frigidaire PLFU1778ES6 FREEZER
Frigidaire PLFU1778ES7 FREEZER
Frigidaire PLFU1778ES8 FREEZER
Frigidaire PLFU2067DS0 Frigidaire/freezer
Frigidaire PLFU2067DS1 Frigidaire/freezer
Frigidaire PLFU2067DS2 Frigidaire/freezer
Frigidaire PLFU2067DS3 Frigidaire/freezer
Frigidaire PLFU2067DS4 Frigidaire/freezer
Frigidaire PLGC30S8ACA Frigidaire/cooktop
  #2 (permalink)
Old 07-04-2013, 06:17 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Not sure what you mean.
An element will not be on all the time as it is controlled by the oven sensor temperature. Also most units will switch back and forth between the bake and broil elements when in preheat and bake modes. This provides a more even temperature gradient in the oven.
What if any other symptoms do you have?
__________________
  #3 (permalink)
Old 07-05-2013, 06:29 AM
Junior Member
Default
Sorry. Should have been more clear. Bottom element stopped working but broil element would still work even during pre-heat however oven would not get to temperature setting. Changed bottom element and the element still does not get hot. When I changed the element it heated up momentarily the first time i used it. After that nothing.
  #4 (permalink)
Old 07-05-2013, 08:22 AM
Senior Expert
APP Volunteer
Default
Parts for Frigidaire PLEB30S9FCA Wall Oven - AppliancePartsPros.com
Here is the wiring diagram.
http://manuals.frigidaire.com/prodin.../318046235.pdf
First I would remove power from the unit and pull the bake element.
Then check it with a meter,
Just in case it blew as soon as power was applied to it.
If OK then check that the wires to the element are OK.
Check that the connections and soldering on the control board to the bake element are OK.
If they are OK then odds are high that the control board is toast.
Since it stays in preheat the board is getting the correct temperature reading from the oven sensor but for some reason is not turning on the bake element.
__________________
  #5 (permalink)
Old 07-08-2013, 08:10 AM
Junior Member
Default
Thanks for the help. So do I need the control panel (AP3950999) or just the Clock/timer (3781481)
  #6 (permalink)
Old 07-08-2013, 02:24 PM
Senior Expert
APP Volunteer
Default
You should only need the clock/timer
Part number: AP3781481
__________________
  #7 (permalink)
Old 07-09-2013, 06:09 AM
Junior Member
Default
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven control panel says "locked door" and does not work. Need new control panel. ferhan Oven Repair (including Ranges and Cooktops) 3 08-15-2011 06:45 PM
Need help removing control panel and front panel to get at the drain pump jthenne Washer Repair 2 02-16-2011 02:15 PM
Control Panel or Electronic Control - which causes blinking panel lights? MarcLCH Dishwasher Repair 1 02-25-2010 03:25 AM
tranformer blew on control panel need specs for new transformer not control panel kaydog2009 Oven Repair (including Ranges and Cooktops) 0 05-11-2009 07:22 AM
Replace control panel or just control panel housing? Max Strano Dishwasher Repair 1 08-26-2008 06:02 PM
