I seem to have a problem with the keypanel. All the keys work except the numbers (only 7 works). I replaced the whole controller, but it did not fix it. Is it a problem with the ribbon cable ? I also ordered new key panel part number GEH WB27T110876 but had to return it as it was not correct part for this model. Do you have the correct key panel or just ribbon cable ? Thanks so much.
It would be best to call the parts representatives. Here is what I find when I look up your models keypad. Click on the picture for more info on it. Part number: AP3205145
I cannot find any info on the part number for it that you gave. Even tried Google and all that came up was your post. |
THIS FORUM IS DEAD!!!!!!! |
