Discuss
bake element for old Whirlpool - RYE1600P2
 in
I have an old Whirlpool in-the-wall oven (model# RYE1600P2) and the bake element has gone out. I ordered part #
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » bake element for old Whirlpool - RYE1600P2
  #1 (permalink)
Old 06-25-2013, 04:41 PM
Junior Member
cay9999 is on a distinguished road
Default bake element for old Whirlpool - RYE1600P2
Brand: Whirlpool   Age: More than 10 years
I have an old Whirlpool in-the-wall oven (model# RYE1600P2) and the bake element has gone out. I ordered part # AP3095829 (which looks like the existing part) but tech dept researched and came back with part #AP3035472 (which does not look like the existing part). Is there a difference or will either work?
  #2 (permalink)
Old 06-26-2013, 04:01 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
It does not look to me that either will work.
The part AppliancePartsPros gave has the connections facing up.
The distance between the connections is 14 1/2 inches.
The parts you found has the connections facing each other.
The distance between the connections is 12 3/4 inches.
I used the pictures of the elements to figure out the above so it does depends on the pictures being correct.
Also that the grid used on both are the same re: each square is one inch.
Which way the connectors face may not make a difference but the distance between them definitely will.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Model RF365BXPN Lwr Bake Element KevinLee Oven Repair (including Ranges and Cooktops) 3 04-19-2013 03:58 AM
Bake Element Not heating Whirlpool oven 3MTA3 Oven Repair (including Ranges and Cooktops) 5 11-11-2012 03:52 AM
Whirlpool Oven - Lower bake element not heating dannyz Oven Repair (including Ranges and Cooktops) 1 12-10-2010 04:47 PM
Whirlpool Oven Bake element replacement carmela Oven Repair (including Ranges and Cooktops) 1 12-21-2009 08:02 PM
whirlpool oven bake element R. Palma Oven Repair (including Ranges and Cooktops) 3 01-13-2009 10:16 AM
