Discuss
How to access/change control panel
 in
Need some guidance,please. I've determined that the control panel is defective and I'm trying to find step-by-step instructions as how
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to access/change control panel
  #1 (permalink)
Old 06-23-2013, 12:25 AM
Junior Member
Masaka is on a distinguished road
Default How to access/change control panel
Model Number: ACS3350AS   Brand: Amana   Age: 5 - 10 years
Need some guidance,please. I've determined that the control panel is defective and I'm trying to find step-by-step instructions as how best to access and replace this unit. Has someone done this? If so, your help would be most appreciated. I'm having a difficult time removing the front cover and don't wish to dismantle unnecessary components to accomplish my task. Thank you
(Quick update: I'm mentioned that my diagnosis led me to condemn the control board. Actually, when using the oven or the broiler, initially they would work just fine and start To heat up. Then on reaching about 350, would Beep and shut off and show code F3. Then, it would keep showing the same Code until the appliance cooled down. Tested resistance on the temperature sensor. About 1,000 ohms. Why in specs, but changed it, regardless. So, I'm thinking the wiring from the sensor to the control panel could be defective. Highly doubtful. Assuming its the control panel. Either way, I need to access the panel to check continuity and if ok, then to remove the panel and send it out for repairs. Is there ANYTHING else, that I should test? Any suggestions would be most welcome)
Related Models
Amana ACS3350AS RANGE- S/C S/I GAS
Amana ACS3350AW RANGE- S/C S/I GAS
Amana ACS4140BB RANGE- S/C S/I ELE
Amana ACS4140BW RANGE- S/C S/I ELE
Amana ACS4250AB RANGE- S/C S/I ELE
Amana ACS4250AC RANGE- S/C S/I ELE
Amana ACS4250AW RANGE- S/C S/I ELE
Amana ACS4660AB RANGE- S/C S/I DDRAFT ELE
Amana ACS4660AW RANGE- S/C S/I DDRAFT ELE
Whirlpool ACS50 FREESTANDING ICE MAKERS
Whirlpool ACS501
Whirlpool ACS502 ICE CUBE MAKER
Whirlpool ACS520XA1 AIR CONDITIONER
Whirlpool ACS602XM Air-conditioner/heat pump
Whirlpool ACS602XT0 Air-conditioner/heat pump
Amana ACS7270AB RANGE- S/C S/I ELE
Amana ACS7270AS RANGE- S/C S/I ELE
Amana ACS7270AW RANGE- S/C S/I ELE
Whirlpool ACS802XM Air-conditioner/heat pump
Whirlpool ACS802XT0 Air-conditioner/heat pump
Whirlpool ACS802XV0
Whirlpool ACS802XV1
Amana ACS902W GAS CARTRIDGE
General Electric ACSK15AH01 Pers elect
General Electric ACSK15AJ01 Pers elect
Amana ACT100E RANGE- S/C S/I DDRAFT GAS
Amana ACT100W RANGE- S/C S/I DDRAFT GAS
Amana ACT100WW RANGE- S/C S/I DDRAFT GAS
Amana ACT101E RANGE- S/C S/I DDRAFT GAS
Amana ACT101E ELE CARTRIDGE
Amana ACT101WW RANGE- S/C S/I DDRAFT GAS
Amana ACT101WW ELE CARTRIDGE
Amana ACT11 Freezer - Chest
Amana ACT110E RANGE- S/C S/I DDRAFT GAS
Amana ACT110W RANGE- S/C S/I DDRAFT GAS
Amana ACT110WW RANGE- S/C S/I DDRAFT GAS
Amana ACT111E RANGE- S/C S/I DDRAFT GAS
Amana ACT111E ELE CARTRIDGE
Amana ACT111WW RANGE- S/C S/I DDRAFT GAS
Amana ACT111WW ELE CARTRIDGE
General Electric ACTK15AH01 Pers elect
General Electric ACTK15AJ01 Pers elect
Amana ACU-514 RANGE- S/C S/I DDRAFT GAS
Amana ACU-516 RANGE- S/C S/I DDRAFT GAS
General Electric ACU06LAM1 Room air conditioner
Whirlpool ACU072PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU072XE0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU072XE1 THROUGH THE WALL AIR CONDITIONER
Whirlpool ACU072XE2 THROUGH THE WALL AIR CONDITIONER
Whirlpool ACU072XE3 AIR CONDITIONER
Whirlpool ACU072XH0 AIR CONDITIONER
Whirlpool ACU072XJ0 AIR CONDITIONER
Whirlpool ACU072XJ1 AIR CONDITIONER
Whirlpool ACU082XA0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XD0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XD1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU082XW0 AIR CONDITIONER
Whirlpool ACU082XX0 Air-conditioner/heat pump
Whirlpool ACU082XX1 Air-conditioner/heat pump
Whirlpool ACU088PP0 AIR CONDITIONER
Whirlpool ACU088PR0 AIR CONDITIONER
Whirlpool ACU088PR1 AIR CONDITIONER
Whirlpool ACU102PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102PK2 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU102XE0 AIR CONDITIONER
Whirlpool ACU102XE1 AIR CONDITIONER
Whirlpool ACU102XE2 AIR CONDITIONER
Whirlpool ACU102XE3 AIR CONDITIONER
Whirlpool ACU102XH0 AIR CONDITIONER
Whirlpool ACU102XJ0 AIR CONDITIONER
Whirlpool ACU102XJ1 AIR CONDITIONER
Whirlpool ACU102XX0 AIR CONDITIONER
Whirlpool ACU102XX1 AIR CONDITIONER
Whirlpool ACU104PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104PM0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU104XH0 AIR CONDITIONER
Whirlpool ACU104XJ0 AIR CONDITIONER
Whirlpool ACU104XJ1 AIR CONDITIONER
Whirlpool ACU108PP0 AIR CONDITIONER
Whirlpool ACU108PR0 AIR CONDITIONER
Whirlpool ACU108PV AIR CONDITIONER
Whirlpool ACU109PP0 AIR CONDITIONER
Whirlpool ACU109PR0 AIR CONDITIONER
Whirlpool ACU114XE0 AIR CONDITIONER
Whirlpool ACU114XE1 AIR CONDITIONER
Whirlpool ACU114XE2 AIR CONDITIONER
Whirlpool ACU114XE3 AIR CONDITIONER
Whirlpool ACU114XE4 AIR CONDITIONER
Whirlpool ACU114XH0 AIR CONDITIONER
Whirlpool ACU124PK0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PK1 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PK2
Whirlpool ACU124PM0 THROUGH-THE-WALL AIR CONDITIONER
Whirlpool ACU124PP0 AIR CONDITIONER
Whirlpool ACU124XA0 AIR CONDITIONER
Whirlpool ACU124XD0 AIR CONDITIONER
Whirlpool ACU124XD1 AIR CONDITIONER
Whirlpool ACU124XJ0 AIR CONDITIONER
Whirlpool ACU124XJ1 AIR CONDITIONER
Whirlpool ACU124XX0 AIR CONDITIONER
Whirlpool ACU124XX1 AIR CONDITIONER
Whirlpool ACU129PP0 AIR CONDITIONER
Whirlpool ACU129PR0 AIR CONDITIONER
Whirlpool ACU129PV AIR CONDITIONER
Whirlpool ACV052XG0 AIR CONDITIONER
Whirlpool ACV052XG1 AIR CONDITIONER
Whirlpool ACV052XH0 AIR CONDITIONER
General Electric ACV05LAB1 Room air conditioner
General Electric ACV05LAB2 Room air conditioner
General Electric ACV05LAB3 Room air conditioner
General Electric ACV05LAB4 Room air conditioner
General Electric ACV05LAD1 Room air conditioner
General Electric ACV06LAD1 Room air conditioner
Whirlpool ACV072XG0 AIR CONDITIONER
Whirlpool ACV102XG0 AIR CONDITIONER
Whirlpool ACV102XH0 AIR CONDITIONER
Whirlpool ACV122XH0 AIR CONDITIONER
Last edited by Masaka : 06-23-2013 at 01:07 AM. Reason: I would like to invite some feedback and help me through the diagnostics procedure
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control panel access ccmsolutions Refrigerator & Freezer Repair 0 10-01-2012 08:49 AM
matag control panel access mikerodg Washer Repair 0 03-22-2012 03:47 PM
Control Panel Access swabbie Washer Repair 0 01-11-2011 03:10 PM
How to Access Control Panel wgreen584 Washer Repair 3 04-25-2009 12:45 PM
How to access the panel to change temp switch kwmir Washer Repair 0 06-25-2008 10:20 AM
