GE Cooktop Disassembly
I'm trying to disassemble the cooktop and from the exploded view it shows Item 200 as a Tap Foam that holds the Top to the Bottom. How do you seperate? Pry apart, heat gun to melt, cut the foam? Then how do you remove the Tape Foam? It seems from a repair standpoint, this is a long process.
