Discuss
Bottom element not working code F10
 in
My bottom element will not work had it tested and it is working getting code F10. Not sure what else
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Bottom element not working code F10
  #1 (permalink)
Old 06-19-2013, 06:59 PM
Junior Member
CHEVY5637 is on a distinguished road
Default Bottom element not working code F10
Model Number: CFEF355FCB   Brand: Frigidaire   Age: 1 - 5 years
My bottom element will not work had it tested and it is working getting code F10. Not sure what else to do.
Related Models
Frigidaire CFEF355FCB Frigidaire/range
Frigidaire CFEF355FCC ELECTRIC RANGE
Frigidaire CFEF355FCD ELECTRIC RANGE
Frigidaire CFEF355FCE ELECTRIC RANGE
Frigidaire CFEF355FCF ELECTRIC RANGE
Frigidaire CFEF355FCG ELECTRIC RANGE
Frigidaire CFEF355FSA Frigidaire/range
Frigidaire CFEF355FSB Frigidaire Canada/electric Range
Frigidaire CFEF355FSC ELECTRIC RANGE
Frigidaire CFEF355FSD ELECTRIC RANGE
Frigidaire CFEF355FSE ELECTRIC RANGE
Frigidaire CFEF357EB1
Frigidaire CFEF357EC1
Frigidaire CFEF357EC2 Frigidaire Canada/electric Range
Frigidaire CFEF357EQ1
Frigidaire CFEF357ES1
Frigidaire CFEF357GS1 Frigidaire Canada/electric Range
Frigidaire CFEF357GS2 ELECTRIC RANGE
Frigidaire CFEF357GS3 ELECTRIC RANGE
Frigidaire CFEF358EB1 Frigidaire Canada/electric Range
Frigidaire CFEF358EB2 Frigidaire Canada/electric Range
Frigidaire CFEF358EB3 ELECTRIC RANGE
Frigidaire CFEF358EB4 ELECTRIC RANGE
Frigidaire CFEF358EC1 Frigidaire Canada/electric Range
Frigidaire CFEF358EC2 Frigidaire Canada/electric Range
Frigidaire CFEF358EC3 ELECTRIC RANGE
Frigidaire CFEF358EC4 ELECTRIC RANGE
Frigidaire CFEF358EC5 ELECTRIC RANGE
Frigidaire CFEF358EQ1 Frigidaire Canada/electric Range
Frigidaire CFEF358ES1 Frigidaire Canada/electric Range
Frigidaire CFEF358ES2 Frigidaire Canada/electric Range
Frigidaire CFEF358ES3 ELECTRIC RANGE
Frigidaire CFEF358ES4 ELECTRIC RANGE
Frigidaire CFEF364HSA ELECTRIC RANGE
Frigidaire CFEF364HSB ELECTRIC RANGE
Frigidaire CFEF364HSC ELECTRIC RANGE
Frigidaire CFEF364HSD ELECTRIC RANGE
Frigidaire CFEF364HSE ELECTRIC RANGE
Frigidaire CFEF366EMB Frigidaire/range
Frigidaire CFEF366EMC Frigidaire/range
Frigidaire CFEF366EMD Frigidaire/range
Frigidaire CFEF366EME ELECTRIC RANGE
Frigidaire CFEF366EMF ELECTRIC RANGE
Frigidaire CFEF366EMG ELECTRIC RANGE
Frigidaire CFEF366EMH ELECTRIC RANGE
Frigidaire CFEF366EMJ ELECTRIC RANGE
Frigidaire CFEF366EMK ELECTRIC RANGE
Frigidaire CFEF366GBA Frigidaire/range
Frigidaire CFEF366GBB ELECTRIC RANGE
Frigidaire CFEF366GBD ELECTRIC RANGE
Frigidaire CFEF366GBE ELECTRIC RANGE
Frigidaire CFEF366GCA Frigidaire/range
Frigidaire CFEF366GCB ELECTRIC RANGE
Frigidaire CFEF366GCC ELECTRIC RANGE
Frigidaire CFEF366GCD ELECTRIC RANGE
Frigidaire CFEF366GCE ELECTRIC RANGE
Frigidaire CFEF366GCG ELECTRIC RANGE
Frigidaire CFEF366GCH ELECTRIC RANGE
Frigidaire CFEF366GSA Frigidaire/range
Frigidaire CFEF366GSB ELECTRIC RANGE
Frigidaire CFEF366GSD ELECTRIC RANGE
Frigidaire CFEF366GSE ELECTRIC RANGE
Frigidaire CFEF368JCA ELECTRIC RANGE
Frigidaire CFEF368JCB ELECTRIC RANGE
Frigidaire CFEF368JCC ELECTRIC RANGE
Frigidaire CFEF368JCD ELECTRIC RANGE
Frigidaire CFEF370GS1 Frigidaire Canada/electric Range
Frigidaire CFEF370GS2 ELECTRIC RANGE
Frigidaire CFEF372BC3 Frigidaire Canada/electric Range
Frigidaire CFEF372EB1 Frigidaire Canada/electric Range
Frigidaire CFEF372EB2 Frigidaire/range
Frigidaire CFEF372EB3 Frigidaire Canada/electric Range
Frigidaire CFEF372EB4 Frigidaire Canada/electric Range
Frigidaire CFEF372EB5 ELECTRIC RANGE
Frigidaire CFEF372EB6 ELECTRIC RANGE
Frigidaire CFEF372EC1 Frigidaire Canada/electric Range
Frigidaire CFEF372EC2 Frigidaire/range
Frigidaire CFEF372EC3 Frigidaire Canada/electric Range
Frigidaire CFEF372EC4 Frigidaire Canada/electric Range
Frigidaire CFEF372EC5 ELECTRIC RANGE
Frigidaire CFEF372EC6 ELECTRIC RANGE
Frigidaire CFEF372EC7 ELECTRIC RANGE
Frigidaire CFEF372EQ1 Frigidaire Canada/electric Range
Frigidaire CFEF372EQ2 Frigidaire/range
Frigidaire CFEF372EQ3 Frigidaire Canada/electric Range
Frigidaire CFEF372EQ4 Frigidaire Canada/electric Range
Frigidaire CFEF372EQ5 ELECTRIC RANGE
Frigidaire CFEF372ES1 Frigidaire Canada/electric Range
Frigidaire CFEF372ES2 Frigidaire/range
Frigidaire CFEF372ES3 Frigidaire Canada/electric Range
Frigidaire CFEF372ES4 Frigidaire Canada/electric Range
Frigidaire CFEF372ES5 ELECTRIC RANGE
Frigidaire CFEF372ES6 ELECTRIC RANGE
Frigidaire CFEF376GBA ELECTRIC RANGE
Frigidaire CFEF376GBB ELECTRIC RANGE
Frigidaire CFEF376GBC ELECTRIC RANGE
Frigidaire CFEF376GBD ELECTRIC RANGE
Frigidaire CFEF376GBE ELECTRIC RANGE
Frigidaire CFEF376GCA ELECTRIC RANGE
Frigidaire CFEF376GCB ELECTRIC RANGE
Frigidaire CFEF376GCC ELECTRIC RANGE
Frigidaire CFEF376GCD ELECTRIC RANGE
Frigidaire CFEF376GCE ELECTRIC RANGE
Frigidaire CFEF376GCF ELECTRIC RANGE
Frigidaire CFEF376GCG ELECTRIC RANGE
Frigidaire CFEF376GSA ELECTRIC RANGE
Frigidaire CFEF376GSB ELECTRIC RANGE
Frigidaire CFEF376GSC ELECTRIC RANGE
Frigidaire CFEF376GSD ELECTRIC RANGE
Frigidaire CFEF376GSE ELECTRIC RANGE
Frigidaire CFES3015LB1 ELECTRIC RANGE
Frigidaire CFES3015LW1 ELECTRIC RANGE
Frigidaire CFES3015LW2 ELECTRIC RANGE
Frigidaire CFES3015LW3 FRIGIDAIRE/ELECTRIC RANGE
Frigidaire CFES3025LB1 ELECTRIC RANGE
Frigidaire CFES3025LB2 ELECTRIC RANGE
Frigidaire CFES3025LB3 ELECTRIC RANGE
Frigidaire CFES3025LS1 ELECTRIC RANGE
Frigidaire CFES3025LS2 ELECTRIC RANGE
Frigidaire CFES3025LS3 ELECTRIC RANGE
  #2 (permalink)
Old 06-23-2013, 03:18 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire CFEF355FCB Range - AppliancePartsPros.com
Here is a tech sheet. I could not find a sheet for a FCB unit so this tech sheet is for a FBC unit. It should be a close match if not exactly the same as your unit.
http://manuals.frigidaire.com/prodin...16458404en.pdf
Have you tried removing power/unplugging the unit for a couple minutes to see if it will reset?
F10 is an overheat error so check the oven sensor.
Below is a good link, check out 7, 8, 20 and 21.
http://www.applianceaid.com/electric...air-topics.php
If it will not reset and the sensor is OK then check the sensor connection on the control board. Check that the connectors are clean and properly crimped. Check for a cold solder joint, they are usually a duller silver and/or have pin holes. While looking at the solder side of the board gently wiggle the connector to see if it's legs move in the solder. A magnifying glass helps here.
If all OK then odds are that the control board is toast.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bottom bake element not working oldmill Oven Repair (including Ranges and Cooktops) 6 06-05-2012 03:44 AM
Bottom oven element not working lavrjn Oven Repair (including Ranges and Cooktops) 0 11-02-2009 06:07 AM
bottom element not working nlorenz Oven Repair (including Ranges and Cooktops) 2 04-10-2009 08:13 PM
Bottom Element Not Working scratchinmyhead Oven Repair (including Ranges and Cooktops) 0 07-28-2008 05:14 PM
Bottom Element not working Kevin G Oven Repair (including Ranges and Cooktops) 0 11-08-2007 06:20 PM
