Discuss
Oven ignightor going on and off
 in
I checked the oven and the ignightor was dim so i installed a new ignightor. I push the clock to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven ignightor going on and off
  #1 (permalink)
Old 06-13-2013, 11:53 AM
Junior Member
peter11203 is on a distinguished road
Default Oven ignightor going on and off
Model Number: fgf337gcb   Brand: Frigidaire   Age: 5 - 10 years
I checked the oven and the ignightor was dim so i installed a new ignightor. I push the clock to put the oven on and it would not go on. I checked it again and watched it go on and off. It would light the flame and then it would go off again. I checked the plug wires that plug into the ignightor. I even cut out the plug so it was a direct hook up. I checked the control panel . I didn't see any burnt spots but it could be bad. I am not sure if it's the control panel or the gas valve I need your help.
Related Models
Frigidaire FGF337GCB GAS RANGE
Frigidaire FGF337GCC GAS RANGE
Frigidaire FGF337GCD GAS RANGE
Frigidaire FGF337GCE GAS RANGE
Frigidaire FGF337GCF GAS RANGE
Frigidaire FGF337GCG GAS RANGE
Frigidaire FGF337GCH GAS RANGE
Frigidaire FGF337GCJ GAS RANGE
Frigidaire FGF337GCK GAS RANGE
Frigidaire FGF337GSA Frigidaire/range
Frigidaire FGF337GSB GAS RANGE
Frigidaire FGF337GSC GAS RANGE
Frigidaire FGF337GSD GAS RANGE
Frigidaire FGF337GSE GAS RANGE
Frigidaire FGF337GSF GAS RANGE
Frigidaire FGF337GSG GAS RANGE
Frigidaire FGF337GUA Frigidaire/range
Frigidaire FGF337GUB GAS RANGE
Frigidaire FGF337GUC GAS RANGE
Frigidaire FGF337GUD GAS RANGE
Frigidaire FGF337GUE GAS RANGE
Frigidaire FGF337GUF GAS RANGE
Frigidaire FGF337GWA Frigidaire/range
Frigidaire FGF337GWB GAS RANGE
Frigidaire FGF337GWC GAS RANGE
Frigidaire FGF337GWD GAS RANGE
Frigidaire FGF337GWE GAS RANGE
Frigidaire FGF337GWF GAS RANGE
Frigidaire FGF343BADA Frg(v2) / Gas Range
Frigidaire FGF343BADB Frg(v3) / Gas Range
Frigidaire FGF343BAWA Frg(v1) / Gas Range
Frigidaire FGF343BAWB Frg(v4) / Gas Range
Frigidaire FGF345BHWA Frg(v4) / Gas Range
Frigidaire FGF345BHWB Frigidaire/gas Range
Frigidaire FGF345BHWC Frigidaire/gas Range
Frigidaire FGF345GSA GAS RANGE
Frigidaire FGF345GSB GAS RANGE
Frigidaire FGF345GSC GAS RANGE
Frigidaire FGF345GSD GAS RANGE
Frigidaire FGF348KBA GAS RANGE
Frigidaire FGF348KBB GAS RANGE
Frigidaire FGF348KCA GAS RANGE
Frigidaire FGF348KCB GAS RANGE
Frigidaire FGF348KCC GAS RANGE
Frigidaire FGF348KCD GAS RANGE
Frigidaire FGF348KCE GAS RANGE
Frigidaire FGF348KCF GAS RANGE
Frigidaire FGF348KCG GAS RANGE
Frigidaire FGF348KCH GAS RANGE
Frigidaire FGF348KCJ GAS RANGE
Frigidaire FGF348KCK GAS RANGE
Frigidaire FGF348KMA GAS RANGE
Frigidaire FGF348KMB GAS RANGE
Frigidaire FGF348KSA GAS RANGE
Frigidaire FGF348KSB GAS RANGE
Frigidaire FGF348KSC GAS RANGE
Frigidaire FGF348KSD GAS RANGE
Frigidaire FGF348KSE GAS RANGE
Frigidaire FGF348KSF GAS RANGE
Frigidaire FGF348KSG GAS RANGE
Frigidaire FGF348KSH GAS RANGE
Frigidaire FGF348KSJ GAS RANGE
Frigidaire FGF350BBDA Frg(v1) / Gas Range
Frigidaire FGF350BBDB Frg(v1) / Gas Range
Frigidaire FGF350BBDC Frg(v1) / Gas Range
Frigidaire FGF350BBDD Frg(v2) / Gas Range
Frigidaire FGF350BBDE Frg(v1) / Gas Range
Frigidaire FGF350BBWA Frg(v2) / Gas Range
Frigidaire FGF350BBWB Frg(v2) / Gas Range
Frigidaire FGF350BBWC Frg(v3) / Gas Range
Frigidaire FGF350BBWD Frg(v4) / Gas Range
Frigidaire FGF350BBWE Frg(v2) / Gas Range
Frigidaire FGF350BFDA Frg(v1) / Gas Range
Frigidaire FGF350BFWA Frg(v2) / Gas Range
Frigidaire FGF350MXASA Frigidaire/gas Range
Frigidaire FGF350MXASB Frigidaire/gas Range
Frigidaire FGF351SGWA Frg(v0) / Gas Range
Frigidaire FGF351SGWB Frg(v0) / Gas Range
Frigidaire FGF351SGWC Frg(v0) / Gas Range
Frigidaire FGF352SBDA Frg(v1) / Gas Range
Frigidaire FGF352SBDB Frg(v1) / Gas Range
Frigidaire FGF352SBDC Frg(v1) / Gas Range
Frigidaire FGF352SBDD Frg(v2) / Gas Range
Frigidaire FGF352SBDE Frg(v1) / Gas Range
Frigidaire FGF352SBWA Frg(v2) / Gas Range
Frigidaire FGF352SBWB Frg(v2) / Gas Range
Frigidaire FGF352SBWC Frg(v3) / Gas Range
Frigidaire FGF352SBWD Frg(v4) / Gas Range
Frigidaire FGF352SBWE Frg(v2) / Gas Range
Frigidaire FGF353BADA Frg(v2) / Gas Range
Frigidaire FGF353BADB Frg(v1) / Gas Range
Frigidaire FGF353BADC Frg(v1) / Gas Range
Frigidaire FGF353BADD Frg(v2) / Gas Range
Frigidaire FGF353BADE Frg(v1) / Gas Range
Frigidaire FGF353BADF Frg(v1) / Gas Range
Frigidaire FGF353BADG Frg(v1) / Gas Range
Frigidaire FGF353BADH Frg(v1) / Gas Range
Frigidaire FGF353BADJ Frg(v1) / Gas Range
Frigidaire FGF353BAWA Frg(v1) / Gas Range
Frigidaire FGF353BAWB Frg(v2) / Gas Range
Frigidaire FGF353BAWC Frg(v3) / Gas Range
Frigidaire FGF353BAWD Frg(v4) / Gas Range
Frigidaire FGF353BAWE Frg(v2) / Gas Range
Frigidaire FGF353BAWF Frg(v2) / Gas Range
Frigidaire FGF353BAWG Frg(v2) / Gas Range
Frigidaire FGF353BAWH Frg(v2) / Gas Range
Frigidaire FGF353BAWJ Frg(v2) / Gas Range
Frigidaire FGF353CASA Frg(v1) / Gas Range
Frigidaire FGF353CASB Frg(v1) / Gas Range
Frigidaire FGF353CASC Frg(v1) / Gas Range
Frigidaire FGF353CASD Frg(v2) / Gas Range
Frigidaire FGF353CASE Frg(v3) / Gas Range
Frigidaire FGF353CASF Frg(v3) / Gas Range
Frigidaire FGF353CASG Frg(v3) / Gas Range
Frigidaire FGF353CASH Frg(v0) / Range
Frigidaire FGF353CASJ Frg/gas Range
Frigidaire FGF353CATA Frg(v1) / Gas Range
Frigidaire FGF353CATB Frg(v2) / Gas Range
Frigidaire FGF353CATC Frg(v3) / Gas Range
Frigidaire FGF353CATD Frg(v4) / Gas Range
  #2 (permalink)
Old 06-13-2013, 03:09 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
For how long the gas stays on and does the ignitor turns off together with gas?
Would it go back on in a few minutes?
When you are trying it, is the oven reassembled?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-13-2013, 04:04 PM
Junior Member
Default Oven ignightor problem
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Wood it go back on in a few minutes?
Simon.
The first time i was checking it i could not get it to go on at all. I tryed it again it went on for maybe 10 seconds went off for a few seconds and went back on it did that a few time then it stayed on for about a min . I didnt keep it on long everytime i checked it thats what happen. I checked it a few times and yes the gas went off when the ignightor went off. I had just the oven bottom part off that covers the ignightor. The first time i checked it i could not get it to go on at all. If i take the valve wires off and put them together i can tell if its the control panel or the valve right? if it stays bright then the control panel is sending it the right current.
  #4 (permalink)
Old 06-13-2013, 04:07 PM
Junior Member
Default Its for a customer this is the first time i ever saw this problem
  #5 (permalink)
Old 06-13-2013, 04:41 PM
Expert
Default
I don't think that bipassing the gas valve is a good idea. What you can do is to disconnect the ignitor, turn the oven on and check if 120 Volts from the control board stays on.
I'm thinking it is most likely the gas valve.
Here are the breakdown diagrams and Burner parts for Frigidaire FGF337GCB - AppliancePartsPros.com
Simon.
__________________
  #6 (permalink)
Old 06-13-2013, 07:41 PM
Junior Member
Simon.
I was thinking the same thing, but i never saw one break like that everytime i saw one break it was dead. I wanted to ask you something else, I followed the wires from the ignightor the power line goes into 3 wires for the light the control panel and i think the ignightor. It comes out of the spark box and turns into the 3 wires when i pulled the box out the back came out a little and went right back in could this be it? Everything else was working but this don't happen until it has a load on so thats why i am trying to cover all the bases what do you think? Thanks for all of your help
  #7 (permalink)
Old 06-14-2013, 09:57 AM
Expert
Default
When saying "the spark box" do you mean the junction box? Sorry, I do not quite understand what you saying.
Sounds like you are describing the neutral wire, going from the power cord connection to the various parts. The picture might help.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ignightor Problems Jibstretcher Oven Repair (including Ranges and Cooktops) 3 06-13-2013 12:08 PM
ignightor rackman13 Oven Repair (including Ranges and Cooktops) 0 08-01-2012 06:13 PM
bosch gas cooktop ignightor problem brian22 Oven Repair (including Ranges and Cooktops) 0 06-06-2009 01:17 PM
