Discuss
Oven cavity light not working
 in
Hello, My mother has an Amana Big Oven ACF3325AC and the cavity light does notwork. I turned off the power
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven cavity light not working
  #1 (permalink)
Old 06-11-2013, 12:53 PM
Junior Member
BOXXERD is on a distinguished road
Default Oven cavity light not working
Model Number: ACF3325AC   Brand: Amana   Age: More than 10 years
Hello,
My mother has an Amana Big Oven ACF3325AC and the cavity light does notwork. I turned off the power and replaced the light fixture and still nothing.(I confirmed the bulb is good). When I pulled the oven out, I did notice that one of the wires that connect to the light fixture looked a little burned. The"Oven Light" button on the main display does light when pressed. I am willing to replace the display/computer if that is the problem but I'm just notso sure. Any help would be appreciated. Thank you!!!
Related Models
Amana ACF3325AC RANGE- S/C S/I DDRAFT GAS
Amana ACF3325AC RANGE- S/C F/S GAS
Amana ACF3325AS RANGE- S/C S/I DDRAFT GAS
Amana ACF3325AW RANGE- S/C F/S GAS
Amana ACF3335AB RANGE- S/C S/I DDRAFT GAS
Amana ACF3335AC RANGE- S/C S/I DDRAFT GAS
Amana ACF3335AS RANGE- S/C S/I DDRAFT GAS
Amana ACF3335AW RANGE- S/C S/I DDRAFT GAS
Amana ACF3355AB RANGE- S/C S/I DDRAFT GAS
Amana ACF3355AC RANGE- S/C S/I DDRAFT GAS
Amana ACF3355AS RANGE- S/C S/I DDRAFT GAS
Amana ACF3355AW RANGE- S/C S/I DDRAFT GAS
Amana ACF3375AB RANGE- S/C S/I DDRAFT GAS
Amana ACF3375AC RANGE- S/C S/I DDRAFT GAS
Amana ACF3375AS RANGE- S/C S/I DDRAFT GAS
Amana ACF3375AW RANGE- S/C S/I DDRAFT GAS
Amana ACF4205AK RANGE- S/C F/S ELE
Amana ACF4205AT RANGE- S/C S/I DDRAFT GAS
Amana ACF4205AT RANGE- S/C F/S ELE
Amana ACF4215AB RANGE- S/C F/S ELE
Amana ACF4215AC RANGE- S/C F/S ELE
Amana ACF4215AW RANGE- S/C F/S ELE
Amana ACF4225AB RANGE- S/C F/S ELE
Amana ACF4225AC RANGE- S/C F/S ELE
Amana ACF4225AS RANGE- S/C F/S ELE
Amana ACF4225AW RANGE- S/C F/S ELE
Amana ACF422GAB RANGE- S/C F/S ELE
Amana ACF422GAC RANGE- S/C F/S ELE
Amana ACF422GAS RANGE- S/C F/S ELE
Amana ACF422GAW RANGE- S/C F/S ELE
Amana ACF4255AB RANGE- S/C F/S ELE
Amana ACF4255AC RANGE- S/C F/S ELE
Amana ACF4255AW RANGE- S/C F/S ELE
Amana ACF4265AB RANGE- S/C F/S ELE
Amana ACF4265AC RANGE- S/C F/S ELE
Amana ACF4265AS RANGE- S/C F/S ELE
Amana ACF4265AW RANGE- S/C F/S ELE
Amana ACF7225AB RANGE- S/C F/S ELE
Amana ACF7225AC RANGE- S/C F/S ELE
Amana ACF7225AW RANGE- S/C F/S ELE
Whirlpool ACFE0940 Air-conditioner/heat pump
Whirlpool ACFW0940 Air-conditioner/heat pump
Whirlpool ACG052XJ0 AIR CONDITIONER
Whirlpool ACG072XJ0 AIR CONDITIONER
Amana ACG100 RANGE- S/C S/I DDRAFT GAS
Frigidaire ACG130NCD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ACG130NCD1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ACG130NCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ACG130NCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ACG130NLD0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ACG130NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ACG130NLW0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ACG130NLW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ACG130VNCD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ACG130VNCD1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ACG130VNCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ACG130VNCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ACG130VNLD0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ACG130VNLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ACG130VNLW0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ACG130VNLW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ACG133NCD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ACG133NCD1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ACG133NCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ACG133NCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ACG133NLD0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ACG133NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ACG133NLW0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ACG133NLW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ACG150NCD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ACG150NCD1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ACG150NCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ACG150NCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ACG150NLD0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ACG150NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ACG150NLW0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ACG150NLW1 Wwh(v3) / Top Mount Refrigerator
Amana ACG200 GAS CARTRIDGE
Whirlpool ACH082XA0 AIR CONDITIONER
Whirlpool ACH082XD0 AIR CONDITIONER
Whirlpool ACH082XD1 AIR CONDITIONER
Whirlpool ACH082XM0 Air-conditioner/heat pump
Whirlpool ACH082XP0 Air-conditioner/heat pump
Whirlpool ACH082XX0 Air-conditioner/heat pump
  #2 (permalink)
Old 06-11-2013, 01:30 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Unfortunately, the clock/control board is not available any longer.
If you already replaced the light assembly Part number: 31823701
all you can do, is to check the wiring to the light.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-11-2013, 01:34 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
Thanks for your reply. What is the best way to check the wiring? I have a volt meter. Would I just place the two leads of the volt meter on the two ends of the wires? What voltage should I be getting?
  #4 (permalink)
Old 06-11-2013, 02:31 PM
Expert
Default
Hi.
You will be checking the continuity, not the voltage. So, unplug the range, remove the wires from the light socket, set your meter to the ohm scale.
Place one probe to each end of the wire. You should read less then one ohm resistance. Otherwise, the wire is bad.
Simon.
__________________
  #5 (permalink)
Old 06-11-2013, 05:48 PM
Junior Member
Default
Hi.
Simon.
Simon,
Thanks for the reply. Sorry I'm not too good at this. I sort of understand continuity testing, but there were 2 wires connected to the light fixture each going to different points on the oven (I believe one was going to the clock/computer and the other one going to the bottom where the main power cord for the oven was.) Do you mean just test one wire from the back of the fixture to where it connects to the clock/computer and test the other wire from the back of the fixture to where it connects down by the main oven power cord? Thanks again.
  #6 (permalink)
Old 06-11-2013, 06:35 PM
Senior Member
scott5495 is on a distinguished road
Default cavity lite
remove back of range to gain access to fixture. you will have 2 wires on the fixture. set volt meter to read at least 120 volts. plug in range, turn lite on, place leads on fixture wires. if you have 110 to 120 volts, the board is good and you have a lite fixture or bulb problem. if you do not have voltage, take the board off and check for broken solder joints, resolder if necessary. good luck
  #7 (permalink)
Old 06-11-2013, 07:58 PM
Junior Member
Default
Quote:
Scott,
Thank you very much for the info. I will try that very soon. Thanks again to all for your help.....great forum!!
  #8 (permalink)
Old 06-12-2013, 10:19 AM
Expert
Default
Hi.
You should test them both from the light to the control board.
If you are familiar with the testing, do the voltage test.
With the range plugged in, turn the oven light on at the clock/control and check if there 120 Volts AC between the two light socket contacts (with wires on).
If there is proper voltage present you need to check the light bulb and socket connections.
If there is no voltage, then the control is bad.
Simon.
__________________
  #9 (permalink)
Old 06-12-2013, 11:43 AM
Junior Member
Default
Hi.
Simon.
Simon,
Okay thanks. It is a new light fixture but I will test the voltage, which as you indicated, should help to determine if the control board is bad. I confirmed the light bulb is good so that leaves either the wires, control board, or fixture (which is new but you never know). Thanks again....this is a big help!!!!
  #10 (permalink)
Old 06-12-2013, 11:51 AM
Expert
Default
You are welcome.
Keep us posted, please.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Why is Microwave Cavity Light and Fan constantly running RobinG Microwave Repair 0 02-28-2013 12:02 PM
Cavity Light guidance rangernick Microwave Repair 0 07-18-2011 09:20 AM
microwwave cavity light and fan Jmat Microwave Repair 1 10-01-2010 09:01 AM
microwwave cavity light and fan Jmat Microwave Repair 1 10-01-2010 08:39 AM
Need replacement oven cavity McPhee Oven Repair (including Ranges and Cooktops) 2 12-07-2009 04:18 PM
