Discuss
Frigidaire Self-cleaning oven door is locked
 in
I'm sure you see this question a lot and I apologize. I just got my new range/oven mid-'april. My son
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Self-cleaning oven door is locked
  #1 (permalink)
Old 06-11-2013, 05:40 AM
Junior Member
DebbieB. is on a distinguished road
Default Frigidaire Self-cleaning oven door is locked
Brand: Frigidaire   Age: Less than 1 year
I'm sure you see this question a lot and I apologize. I just got my new range/oven mid-'april. My son was using the oven and wanted to clean the mess that occurred. I told him to use the self-cleaning. It was the first time for that. Now the door won't open. I've googled everything, then came across a paper that came with the paperwork stating the racks must be out. I wish that was in the manual. If it was, we both overlooked it. So how do you open it now that it's locked and the racks are inside and apparently not supposed to be? I've unplugged and let it sit and then plugged it back in to no avail (to reset)...I've held the cancel buttom for a few seconds, that didn't work. Thanks for any help.
(Also, the unlock button doesn't work when I've tried that).
  #2 (permalink)
Old 06-11-2013, 04:02 PM
Junior Member
Default
Good thing I didn't wait for an answer.
For anyone who has this problem, I called customer service at Frigidaire, and the woman was extremely helpful. All it was was the protective coating on the rack (that's why they recommend you take it out). It caused the door to stick hard. She said to turn the oven onto 500 to 550F and let it bake for a half hour to 45 minutes, then when done, pull hard as it still may stick. I think I had it on for 15 to 20 minutes and then pulled on it and it opened. After that she said oil the rack where it pulls out automatically when I open the door and also rub it down with wax paper.
Been working great.
  #3 (permalink)
Old 06-16-2013, 12:28 AM
Junior Member
shanewoods21 is on a distinguished road
Default
Oven Cleaning onto 500 to 550F and let it bake for a half hour to 45 minutes, then when done, pull hard as it still may stick. I think I had it on for 15 to 20 minutes and then pulled on it and it opened. After that she said oil the rack where it pulls out automatically when I open the door and also rub it down with wax paper.
Been working great.
Thanks for mentioning solution as well. I have faced the problem earlier but the door opened itself after sometime. I was not able to understand the reason behind it. But i will be bit careful., Thanks again
  #4 (permalink)
Old 06-21-2013, 09:47 AM
Junior Member
Default
Quote:
No problem, Shane. Hopefully, you won't experience it. :-)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Self-Cleaning oven locked with door open lan_rover Oven Repair (including Ranges and Cooktops) 2 05-28-2012 09:06 AM
Oven door locked after cleaning cycle JPeachey Oven Repair (including Ranges and Cooktops) 1 10-25-2010 12:26 PM
Oven door locked after cleaning cycle scottbel Oven Repair (including Ranges and Cooktops) 0 10-18-2010 11:37 AM
Oven door is locked - Like it's in the cleaning mode mimi1 Oven Repair (including Ranges and Cooktops) 0 04-26-2010 07:27 AM
locked oven door, after self-cleaning, F-2 error kenstormy Oven Repair (including Ranges and Cooktops) 0 03-02-2009 10:13 AM
