panderson1263
#1 Posted : Saturday, June 8, 2013 7:23:18 AM(UTC)
panderson1263
I am looking for control parts for the Amana Wall Oven AEW4630DDB. Technician indicates that it needs a new control and membrane, but the membrane is no longer available. I have been able to find a control panel on line, but nothing referencing a membrane. Any help would be appreciated.
#2 Posted : Sunday, June 9, 2013 12:12:45 AM(UTC)
Parts for Amana AEW4630DDB Wall Oven - AppliancePartsPros.com
See the attachment for the tech sheet,
I believe they are referring to the control panel (item 1 in the 02 Control Panel section. It includes a membrane type keypad.
Strange that you need both usually it is one or the other.
The usual way to troubleshoot this is to check the keypad outputs using a meter. Then if they are OK replace the control board.
File Attachment(s):
AEW4630.pdf (485kb) downloaded 3 time(s).
panderson1263
#3 Posted : Sunday, June 9, 2013 7:40:08 AM(UTC)
panderson1263
Thank you Denman. Would these be the part numbers then:
Panl-Cntrl
by Whirlpool
Part Number AP4417518
MFG Part Number 5765M462-60
and
Control, H2 (clock-C
by Whirlpool
Part Number AP4098773
MFG Part Number 74008880
#4 Posted : Sunday, June 9, 2013 12:48:44 PM(UTC)
Yes those look like the correct numbers.
