Discuss
Oven continues to heat far beyond the set point
 in
Hi, I have had this CT130 oven since new in 1993 and up until now have had zero problems! It
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven continues to heat far beyond the set point
  #1 (permalink)
Old 06-05-2013, 08:42 PM
Junior Member
MJBergh is on a distinguished road
Default Oven continues to heat far beyond the set point
Model Number: CT130S-01   Brand: Thermador   Age: More than 10 years
Hi, I have had this CT130 oven since new in 1993 and up until now have had zero problems! It began being sensitive to setting oven temperature as the rotary control switch would begin to run up a temp setting and then go blank lines and would have to start over at the default of 350. I replaced the Switch, p/n 412912, and now am able to set the temp easily up or down. The 'heat' light comes on and the oven continues to heat up well past the set point in a run-a-way condition -- the 'heat' light continues to remain lit. I am assuming the thermistor/thermostat is the culprit but have read several comments regarding the 'Control Board' which is no longer available and would require sending in to a repair facility. Just want a Tech opinion on the testing procedure to identify why this is happening.
Thanks!
Related Models
Thermador CT130W OVEN
Thermador CT130WC OVEN
Whirlpool CT14NKXHN00 REFRIGERATOR
Whirlpool CT14NKXHW00 REFRIGERATOR
Whirlpool CT14NKXJN00 REFRIGERATOR
Whirlpool CT14NKXJW00 REFRIGERATOR
Whirlpool CT14NKXKQ00 REFRIGERATOR
Whirlpool CT14NKXKQ01 REFRIGERATOR
Whirlpool CT14NKXKT00 REFRIGERATOR
Whirlpool CT14NKXKT01 REFRIGERATOR
Whirlpool CT14SKXRQ00 REFRIGERATOR
Whirlpool CT14SKXRT00 REFRIGERATOR
Whirlpool CT14SKXSQ00 REFRIGERATOR
Whirlpool CT14SKXST00 REFRIGERATOR
Crosley CT15A2A REF - TOP MOUNT
Crosley CT15A2LW REF - TOP MOUNT
Crosley CT15A2Q REF - TOP MOUNT
Crosley CT15A2W REF - TOP MOUNT
Crosley CT15F4Q REF - TOP MOUNT
Crosley CT15F4W REF - TOP MOUNT
Crosley CT15G4Q REF - TOP MOUNT
Crosley CT15G4W REF - TOP MOUNT
Crosley CT15X4A REF - TOP MOUNT
Crosley CT15X4W REF - TOP MOUNT
Crosley CT15Y4A REF - TOP MOUNT
Crosley CT15Y4W REF - TOP MOUNT
Crosley CT15Y5A REF - TOP MOUNT
Crosley CT15Y5W REF - TOP MOUNT
Whirlpool CT16SKXRQ00 REFRIGERATOR
Whirlpool CT16SKXSQ00 REFRIGERATOR
Crosley CT17A2A REF - TOP MOUNT
Crosley CT17A2Q REF - TOP MOUNT
Crosley CT17A2W REF - TOP MOUNT
Crosley CT17A3A REF - TOP MOUNT
Crosley CT17A3W REF - TOP MOUNT
Crosley CT17B3A REF - TOP MOUNT
Crosley CT17B3Q REF - TOP MOUNT
Crosley CT17B3W REF - TOP MOUNT
Crosley CT17F4W REF - TOP MOUNT
Crosley CT17G4Q REF - TOP MOUNT
Crosley CT17G4W REF - TOP MOUNT
Crosley CT17X4A REF - TOP MOUNT
Crosley CT17X4W REF - TOP MOUNT
Crosley CT17X7A REF - TOP MOUNT
Crosley CT17X7W REF - TOP MOUNT
Crosley CT17Y4A REF - TOP MOUNT
Crosley CT17Y4W REF - TOP MOUNT
Crosley CT17Y7A REF - TOP MOUNT
Crosley CT17Y7W REF - TOP MOUNT
Whirlpool CT18AKXJW00 TOP-MOUNT REFRIGERATOR
Whirlpool CT18AKXJW01 TOP-MOUNT REFRIGERATOR
Whirlpool CT18AKXKQ00 TOP-MOUNT REFRIGERATOR
Whirlpool CT18AKXKQ01 TOP-MOUNT REFRIGERATOR
Whirlpool CT18AKXKQ02 REFRIGERATOR
Whirlpool CT18AKXKT00 TOP-MOUNT REFRIGERATOR
Whirlpool CT18AKXKT01 TOP-MOUNT REFRIGERATOR
Whirlpool CT18AKXKT02 REFRIGERATOR
Crosley CT18G5B REF - TOP MOUNT
Crosley CT18G5Q REF - TOP MOUNT
Crosley CT18G5U REF - TOP MOUNT
Crosley CT18G5W REF - TOP MOUNT
Crosley CT18G6B REF - TOP MOUNT
Crosley CT18G6U REF - TOP MOUNT
Crosley CT18G6W REF - TOP MOUNT
Whirlpool CT18GKXRQ00 REFRIGERATOR
Whirlpool CT18GKXRQ01 REFRIGERATOR
Whirlpool CT18GKXRT00 REFRIGERATOR
Whirlpool CT18GKXRT01 REFRIGERATOR
Whirlpool CT18GMXRQ00 REFRIGERATOR
Whirlpool CT18GMXRQ01 REFRIGERATOR
Crosley CT19A4A REF - TOP MOUNT
Crosley CT19A4W REF - TOP MOUNT
Crosley CT19A5A REF - TOP MOUNT
Crosley CT19A5B REF - TOP MOUNT
Crosley CT19A5Q REF - TOP MOUNT
Crosley CT19A5W REF - TOP MOUNT
Crosley CT19A6FA REF - TOP MOUNT
Crosley CT19A6FQ REF - TOP MOUNT
Crosley CT19A6FW REF - TOP MOUNT
Crosley CT19B4A REF - TOP MOUNT
Crosley CT19B4Q REF - TOP MOUNT
Crosley CT19B4W REF - TOP MOUNT
Crosley CT19B6FQ REF - TOP MOUNT
Crosley CT19B6FW REF - TOP MOUNT
Crosley CT19F4Q REF - TOP MOUNT
Crosley CT19F4W REF - TOP MOUNT
Crosley CT19F6FQ REF - TOP MOUNT
Crosley CT19F6FW REF - TOP MOUNT
Crosley CT19F6Q REF - TOP MOUNT
Crosley CT19F6W REF - TOP MOUNT
Crosley CT19G4Q REF - TOP MOUNT
Crosley CT19G4W REF - TOP MOUNT
Crosley CT19G6B REF - TOP MOUNT
Crosley CT19G6FQ REF - TOP MOUNT
Crosley CT19G6FW REF - TOP MOUNT
Crosley CT19G6Q REF - TOP MOUNT
Crosley CT19G6W REF - TOP MOUNT
Crosley CT19X3A REF - TOP MOUNT
Crosley CT19X3V REF - TOP MOUNT
Crosley CT19X6A REF - TOP MOUNT
Crosley CT19X6W REF - TOP MOUNT
Crosley CT19X7A REF - TOP MOUNT
Crosley CT19X7W REF - TOP MOUNT
Crosley CT19Y4A REF - TOP MOUNT
Crosley CT19Y4FA REF - TOP MOUNT
Crosley CT19Y4FW REF - TOP MOUNT
Crosley CT19Y4W REF - TOP MOUNT
Crosley CT19Y5FA REF - TOP MOUNT
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
hot point oven cksurg Oven Repair (including Ranges and Cooktops) 0 01-12-2012 12:53 PM
element continues to heat after timer goes to off until unit is unplugged. 123blake Dryer Repair 1 01-30-2011 03:23 AM
Admiral Oven Does Not Heat to Set Point millejef Oven Repair (including Ranges and Cooktops) 2 12-30-2010 04:50 PM
Whirlpool oven doesn't heat up & blower continues to run EdgarM Oven Repair (including Ranges and Cooktops) 0 11-19-2010 11:27 PM
Oven Continues to heat after being turned off Neilroy87 Refrigerator & Freezer Repair 4 10-18-2010 07:08 PM
