Discuss
Sunray Range Oven With Pilot, oven slow to light
 in
I have an older Sunray Range that still has pilot lights. Very recently, the oven has become harder to light,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Sunray Range Oven With Pilot, oven slow to light
  #1 (permalink)
Old 06-04-2013, 04:46 PM
Junior Member
ohiorepair is on a distinguished road
Default Sunray Range Oven With Pilot, oven slow to light
Model Number: SAP28HG-5GN   Brand: -other-   Age: More than 10 years
I have an older Sunray Range that still has pilot lights. Very recently, the oven has become harder to light, and I am not sure it is keeping the proper temperature once lit. The pilot light is on and gets bigger when you turn the oven on. There is also a smaller flame that jumps on underneath when you turn the oven on. According to the manual, the smaller pilot heats the temperature responsive element which opens the valve when hot enough.
I believe the valve is not operating properly and that is most likely due to this element being dirty. I have read that this element can be cleaned, but I am unsure as to how to properly clean it. Any ideas? Also, is the element replaceable without replacing the entire pilot light assembly?
I did a search for my model number in parts but the model is so old, it came up empty.
Any advice would be appreciated.
(Oh and all of the burners on the top of the range work well.)
Related Models
Amana SAP39AA RANGE- S/I STD GAS
Amana SAP39AA/ALL RANGE- S/C S/I DDRAFT GAS
Amana SAP39DA RANGE- S/C S/I DDRAFT GAS
Amana SAP39DA/ALL RANGE- S/C S/I DDRAFT GAS
 SATF7000FS0 WASHER
 SATF7000FS1 WASHER
Maytag SAV205DAWW WASHER-TOP LOADING
Maytag SAV2555AWW WASHER-TOP LOADING
Maytag SAV2655AWW WASHER-TOP LOADING
Maytag SAV3655AWW WASHER-TOP LOADING
Maytag SAV365AAWW WASHER-TOP LOADING
Maytag SAV365ZAWW WASHER-TOP LOADING
Maytag SAV3710AWW WASHER-TOP LOADING
Maytag SAV405DAWW WASHER-TOP LOADING
Maytag SAV405DEWW WASHER-TOP LOADING
Maytag SAV4655AWQ WASHER-TOP LOADING
Maytag SAV4655AWW WASHER-TOP LOADING
Maytag SAV4655EWQ WASHER-TOP LOADING
Maytag SAV4655EWW WASHER-TOP LOADING
Maytag SAV4710AWW WASHER-TOP LOADING
Maytag SAV505DAWQ WASHER-TOP LOADING
Maytag SAV505DAWW WASHER-TOP LOADING
Maytag SAV515DAWW WASHER-TOP LOADING
Maytag SAV515DEWW WASHER-TOP LOADING
Maytag SAV5300AWW WASHER-TOP LOADING
Maytag SAV5401AWW WASHER-TOP LOADING
Maytag SAV5600AWW WASHER-TOP LOADING
Maytag SAV5701AWQ WASHER-TOP LOADING
Maytag SAV5701AWW WASHER-TOP LOADING
Maytag SAV5710AWW WASHER-TOP LOADING
Maytag SAV571EEWW WASHER-TOP LOADING
Maytag SAV5910AWW WASHER-TOP LOADING
Maytag SAV5910EWW WASHER-TOP LOADING
Maytag SAW25K3S WASHER-TOP LOADING
Whirlpool SAWB600HQ0 AUTOMATIC WASHER
Whirlpool SAWB600JQ0 WASHER
Whirlpool SAWB600JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800HQ0 AUTOMATIC WASHER
Whirlpool SAWS800JQ0 WASHER
Whirlpool SAWS800JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800JQ2 WASHER
Whirlpool SAWS800MQ0 AUTOMATIC WASHER
Whirlpool SAWS900HQ0 WASHER
Whirlpool SAWS900JQ0 WASHER - DIRECT DRIVE
Whirlpool SAWS900MQ0 AUTOMATIC WASHER
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef oven pilot light won't light. dugduzrepairs Oven Repair (including Ranges and Cooktops) 0 10-20-2011 09:08 PM
old mobile home gas range - oven is very slow to light AONE Oven Repair (including Ranges and Cooktops) 0 12-20-2009 11:46 AM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 12:36 PM
oven ignitor not clicking, but pilot will light manually and then the oven will work rosscol Oven Repair (including Ranges and Cooktops) 0 09-10-2008 05:37 PM
oven ignitor not clicking, but pilot will light manually and oven work then rosscol Oven Repair (including Ranges and Cooktops) 1 09-03-2008 04:30 PM
