Discuss
Frigidaire Electric Oven Doesn't Heat
 in
Several days after clean mode both, bake and broil element don't heat. Power is good to poles on the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Electric Oven Doesn't Heat
  #1 (permalink)
Old 02-07-2008, 05:57 PM
sharzaz sharzaz is offline
Junior Member
sharzaz is on a distinguished road
Default Frigidaire Electric Oven Doesn't Heat
Model Number: plef398ccc   Brand: Frigidaire   Age: 1 - 5 years
Several days after clean mode both, bake and broil element don't heat. Power is good to poles on the back. Elements read about .13 ohms but no juice when controls are on and testing for 240v touching element connections,one probe on each side. Is there an in-line fuse ? What does it look like ? Can I find a schematic somewhere on the net ? Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-07-2008, 06:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad Electronic Oven Control (EOC) which has to be replaced.
- The part number for the EOC is AP3215567
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-08-2008, 03:17 PM
Junior Member
Default frigidaire electric oven dosn't heat
The temperture display work as does the convection fan, heat display for broil or bake elements. Is there an in line fuse ?
  #4 (permalink)
Old 02-08-2008, 03:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
There is no fuses and the problem has nothing to do with the display.
There is a few relays in the EOC which supplied power to the heating elements.
__________________
  #5 (permalink)
Old 02-08-2008, 04:56 PM
Junior Member
Default
Can the relays be replaced or is the only option is to spend $200 on the EOC?
  #6 (permalink)
Old 02-08-2008, 05:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If there would be any options I will let you know, but not in this case.
__________________
  #7 (permalink)
Old 02-09-2008, 04:56 PM
Junior Member
Default
The wife happened to try the preheat (400) and the top element heated to maybe 250. does this confirm the EOC's kaput? Thanks for the help and patients!
  #8 (permalink)
Old 02-09-2008, 05:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If there is the right power to the unit - most likely the problem caused by the EOC.
__________________
  #9 (permalink)
Old 11-02-2008, 09:29 PM
paulos paulos is offline
Junior Member
paulos is on a distinguished road
Default Used Frigidaire won't heat to red and clock wont work
I just bought a used Frigidaire electric oven (white). When I plugged it in the clock worked then it conked out. Also the stove elements wont get red hot - my eggs took about 8 minutes to cook and even then they were runny.
I looked at the fuse, it is 15 A - could this be too low? I am not sure what an EOC is, but if it's 200 and I just spent 90 for the oven itself, I dont wanna get one!
TY
  #10 (permalink)
Old 11-03-2008, 02:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the range?
If this range is electric then there are suppose to be 240 volts outlet for the range and a double circuit breaker (at least 30 amps each) in the breaker box.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Electric stove/cooktop's element will not shut off Morris Oven Repair (including Ranges and Cooktops) 13 10-24-2008 02:54 PM
Frigidaire electric dryer outlaw Dryer Repair 1 01-19-2008 07:42 PM
Frigidaire Electric Oven Rear burner light wont go off seagullgeneral Oven Repair (including Ranges and Cooktops) 1 12-14-2007 05:58 PM
Electric Oven Broiler No Heat APSMARK Oven Repair (including Ranges and Cooktops) 0 11-08-2007 07:19 PM
Electric oven takes a long time to heat kuroda01 Oven Repair (including Ranges and Cooktops) 0 11-04-2007 08:24 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
