Discuss
Frigidaire Electric Oven Doesn't Heat
 in
Had the same problem - This posting solved the problem for me! Misc Ads By Google
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Electric Oven Doesn't Heat
  #11 (permalink)
Old 03-08-2009, 01:35 PM
Junior Member
johnyy664 is on a distinguished road
Default Solution to the problem!
Misc
Ads By Google
  #12 (permalink)
Old 06-27-2009, 06:38 PM
Junior Member
DiggerW is on a distinguished road
Default same problem, different cause
Gene did point this out, but I wanted to clearly add:
I had the same problem and identified to be a problem not with the Electronic Oven Control, but with *the power source to the oven.*
I don't know a good way for a non-electrician to confirm you're getting the 220V you're supposed to -- in my case, the sparks coming out of the makeshift duct-taped extension cord when I kicked it were a solid indicator.
  #13 (permalink)
Old 01-20-2010, 05:48 PM
Junior Member
fitkoc is on a distinguished road
Default
hi there, we have a 2 year old frigidaire ES510L Electric Range, all of a sudden the oven only reaches half of the temperature requested, would this be the same issue, the EOC, so basically the computer that controls and sets the oven temp? the top elements work fine, if we used convection would that be affected as well by the EOC not working properly. appreciate your help - i will miss my oven every single day!
  #14 (permalink)
Old 01-20-2010, 05:50 PM
Junior Member
Default same issue? help?
  #15 (permalink)
Old 01-20-2010, 07:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The model number you posted does not come up. Verify and repost it.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #16 (permalink)
Old 01-21-2010, 06:30 PM
Junior Member
Default
sorry Gene, it's model FEFLZ87GCA, s/n BF74946804. Is this easy to fix, could a normal guy fix and replace?
  #17 (permalink)
Old 01-22-2010, 12:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing you may want to do is check the oven temperature probe (#37 on the diagram) resistance. The normal resistance suppose to be about 1100 Ohms at the room temperature. You have to have a simple ohmmeter in order to do it.
Post the result.
__________________
  #18 (permalink)
Old 10-28-2010, 02:26 PM
Junior Member
Iris Whitehead is on a distinguished road
Default
I have the same problem as the person above. I was using the oven on bake last Easter and the oven made a popping sound and went off. I assumed the bake element went out. I have model #FED355EBA, it's only 4 years old. The oven element costs around $100 so I had to wait until 10/27 to order it and received today, put it in, and the oven still doesn't work. Please advise ASAP. I need my oven Sat. Thanks. Iris Whitehead
  #19 (permalink)
Old 12-31-2010, 06:53 AM
Junior Member
jsw9674 is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Most likely the problem is a bad Electronic Oven Control (EOC) which has to be replaced.
- The part number for the EOC is AP3215567
Gene,
I have a similiar problem and it sounds like the EOC needs to be replaced. I heard a pop and the stove works, but not the oven.
Is this something I should be able to replace myself (as I'm fairly handy) and should I go through specific checks before purchasing the EOC? Also, any advice on what to do/not do when replacing the EOC?
Thank you for your time.
Jim
  #20 (permalink)
Old 01-31-2011, 04:06 PM
Junior Member
mcdowell_112 is on a distinguished road
Default
I have a frigidaire range unit it will call for bake and broil but will not heat is the board bad?model #FEF326BB.The top elements work fine and I have power coming to the left side of elements but not on the right side.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire electric double oven jjmj Oven Repair (including Ranges and Cooktops) 0 11-24-2009 10:06 AM
Frigidaire Double Wall Oven (Electric) A87CEO Oven Repair (including Ranges and Cooktops) 1 11-17-2009 09:24 AM
Frigidaire Electric Oven Won't turn off bmutrux Oven Repair (including Ranges and Cooktops) 0 10-27-2009 10:47 AM
F8 Error on Frigidaire Double Electric Oven Elizabeth Varjas Oven Repair (including Ranges and Cooktops) 0 05-25-2009 08:57 AM
Frigidaire electric oven jbustle Oven Repair (including Ranges and Cooktops) 1 03-13-2009 06:45 AM
