Discuss
oven door hinge
 in
I purchased from this site and installed two new door hinges, part no. AP368960. Seemed very simple. But the door
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven door hinge
  #1 (permalink)
Old 02-07-2008, 05:34 PM
michaelmag michaelmag is offline
Junior Member
michaelmag is on a distinguished road
Default oven door hinge
Model Number: svd48600p   Brand: Jenn-Air   Age: 5 - 10 years
I purchased from this site and installed two new door hinges, part no. AP368960. Seemed very simple. But the door doesn't close tightly. Not even tight enough to push the button to turn the oven light off. I've taken it off and reinstalled it but can't see what might be wrong.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-07-2008, 06:22 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem caused by the door hinge receptacles (#6 on the body break down diagram).
Replace the receptacles if there is not possible to adjust them.
- The part number for the door hinge receptacle is AP4090071
Here are the break down diagrams for the Jenn Air oven Model SVD48600P
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-11-2008, 09:58 AM
Junior Member
Default
golly, my oven doesn't look exactly like that. Are those "receptacles" the pins that the hinges hang on inside the body? behind the hinge retainer and the hinge cover, items 10 and 11? Thanks
  #4 (permalink)
Old 02-11-2008, 10:47 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
The break down diagrams, I referred to, are corresponding to the model number you posted. On other side this is not a picture - just a schematic.
You were right. The hinge receptacle is an assembly of a couple of pins that the hinge hang on inside the body and it is behind the hinge retainer and the hinge cover.
__________________
  #5 (permalink)
Old 02-29-2008, 07:35 PM
rpdugan rpdugan is offline
Junior Member
rpdugan is on a distinguished road
Default
I have this exact same problem on this exact same model, the SVD48600P. I just recieved my second set of hinges...and I have the same problem. Just does not close tightly? What can be wrong with the pins?? Especially, if the original hinges closed fine? Is it possible that the new hinges are just not made the same as the old ones?
Did the above advice fix your problem???
  #6 (permalink)
Old 02-29-2008, 07:58 PM
Junior Member
Default
I recieved this part from Maytag...71003351. Is this the same hinge as the AP386960 hinge, or did they send me the wrong hinge?
  #7 (permalink)
Old 02-29-2008, 08:20 PM
Junior Member
Default
I checked my recpeticals...they look brand new...tight as a drum. I really do not think this is the problem. There is also no way to adjust them...
I think the new hinge is just slightly different that the original...which is a real problem as my door does not close....
  #8 (permalink)
Old 02-29-2008, 10:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi rpdugan,
The correct Maytag part number for the door hinge for your oven is 71003353 which crosses over to the APP part number AP368960.
__________________
  #9 (permalink)
Old 02-29-2008, 11:00 PM
Junior Member
Default
So, I have the wrong hinge??? Pretty sure about that? That would sure answer my problem...
  #10 (permalink)
Old 03-03-2008, 08:34 PM
Junior Member
Default
the first set of hinges I got was the part ending in the 3... Still not working right...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hinge on metal door is broken BAKERWG Oven Repair (including Ranges and Cooktops) 1 02-05-2008 07:49 AM
LG Door hinge/springs help tmb Dishwasher Repair 1 01-03-2008 06:19 PM
Spring Poppped Off Door Hinge rblueder Oven Repair (including Ranges and Cooktops) 1 12-06-2007 05:31 PM
Replacing Oven door hinge DHudson Oven Repair (including Ranges and Cooktops) 0 10-30-2007 05:22 PM
Broken door hinge dbrock Dishwasher Repair 1 09-20-2007 03:54 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
