Discuss
oven door hinge
 in
You got the right hinges and you are saying there is nothing with the hinge receptacles... looks like the door
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven door hinge
  #11 (permalink)
Old 03-03-2008, 09:36 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You got the right hinges and you are saying there is nothing with the hinge receptacles... looks like the door frame or the inner door panel are slightly bend.
__________________
Professional appliance repair in Los Angeles, California.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 04-03-2008, 06:19 PM
michaelmag michaelmag is offline
Junior Member
michaelmag is on a distinguished road
Default
I apologize, but I have just today checked this thread and seen the posts from RPDugan. The short answer is that my oven door still does not close. I don't see at all that my hinge mounting pins are adjustable. Unfortunately, in order for me to really check it out, I'd have to disconnect the gas feed (I have a gas cook top) and the down-draft vent duct in order to pull my oven out far enough to see if I can get to those pins. From the outside, though, I don't see at all how they'd be adjustable. So for now, I'm left with an oven door that doesn't close, and every time we use the oven we can feel heat escaping. And I've pulled the oven light bulb since it stayed on all the time with the button not being depressed. Would the hinge retainer or cover plate make a difference? should I replace those? I can't tell from a mechanical perspective why the door doesn't close. It's almost as if the spring just isn't short/taught enough. I don't see why a slightly bent inner door panel, like was mentioned for RPDugan, would make a difference. Mine doesn't look bent. But maybe I should whale away at it with a rubber mallet!!! (Just kidding). Gene, what are the chances you make house calls? Or, is this something my local appliance repair guy should be able to figure out? I'm out of warranty. The oven is 8 years old. Thanks for your help. I'll check back here more often. By the way. I said that my oven didn't look like that in the diagram because my hinge mounting pins run horizontally and part 6 that was referred to looks more vertical to me. Is there a horizontal steel pin inside that part? Thanks
  #13 (permalink)
Old 04-04-2008, 03:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi michaelmag,
I found the Technical Bulletin issued by Maytag, concerning the same problem with the oven door like yours.
The model number of your range is not listed there, but I believe this is the only solution.
It is very important to replace both the door hinges and receptacles to have it work properly.
I do make a house calls but only in Orange County.
__________________
  #14 (permalink)
Old 04-21-2008, 08:04 PM
Junior Member
Default
So, Gene, I'll give replacing those hinge receptacles a try. How exactly do you get to them? It's really not clear to me from viewing the schematic just how to do that. And for the folks at this site. If I do that and the door still doesn't close, can I return hinges and the receptacles? Thanks.
  #15 (permalink)
Old 04-28-2008, 03:05 PM
Adam / APP Team Adam / APP Team is offline
Service Pro
APP Team
Adam / APP Team is on a distinguished road
Default
Dear michaelmag,
This is a follow up to a voicemail I left at your office about your order. Please call me toll free at 1-877-477-7278 X 105 between the hours of 7am-6pm PST to answer any questions you may have about parts you have ordered through us.
I will be glad to help
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices.
Thank you for supporting our free repair help forum.
  #16 (permalink)
Old 10-21-2008, 08:19 PM
Junior Member
Default That worked
It's taken me too long to post, but I took Adam's advice and installed new hinge receptacles and that did, in fact, do the trick. Looking at the old receptacles when I had them out it was obvious that they had bent over time. So the service bulletin was right. If you replace the hinges, you should replace the receptacles as well. Now my light doesn't work and I'm thinking somehow my light socket got fried. Maybe because I pulled the bulb and left the glass off since the light was on all the time because my door didn't close all the way. does that sound right? Does the glass insulate the socket and prevent it from burning up?
  #17 (permalink)
Old 10-21-2008, 08:20 PM
Junior Member
Default Sorry, Gene
I meant Gene's advice. Who's Adam, anyway?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hinge on metal door is broken BAKERWG Oven Repair (including Ranges and Cooktops) 1 02-05-2008 07:49 AM
LG Door hinge/springs help tmb Dishwasher Repair 1 01-03-2008 06:19 PM
Spring Poppped Off Door Hinge rblueder Oven Repair (including Ranges and Cooktops) 1 12-06-2007 05:31 PM
Replacing Oven door hinge DHudson Oven Repair (including Ranges and Cooktops) 0 10-30-2007 05:22 PM
Broken door hinge dbrock Dishwasher Repair 1 09-20-2007 03:54 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
