I'm looking to self repair my frigidaire FGFL466ASD gas oven that will not heat. The broiler works, and I can see the oven igniter glows when set oven to 'on'. I'm thinking that the oven dual safety valve could be the problem (no sound of gas flow after igniter is ready). Does this sound about right? Is there another issue that could be the cause? I'm a novice at this. Thanks in advance.
