Discuss
Oven won't turn off- even with new control board
 in
I just replaced the control board for my whirlpool double oven mod# RBD305PDB12 when I switched the breaker on a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't turn off- even with new control board
  #1 (permalink)
Old 05-26-2013, 08:21 PM
Junior Member
Sandrahyll is on a distinguished road
Default Oven won't turn off- even with new control board
Model Number: RBD305PDB12   Brand: Whirlpool   Age: More than 10 years
I just replaced the control board for my whirlpool double oven mod# RBD305PDB12 when I switched the breaker on a "PF" was on the screen, I was able to hit all the buttons except the off buttons (they didn't beep when puse) - so I realigned the ribbon cable. The second time I switched the breaker on all the buttons worked but the oven wouldn't turn off (the off button made the sound of working) and continued to get hot.
The reason we bought the new control board is because the oven wouldn't turn off and would get so hot that it would lock the oven. What could be the problem if it's not the control board?
Btw, the clock still doesn't work either, I'm able to set the clock but it turns off (again, same issue we had with the old control board....
Thanks!
Related Models
Whirlpool RBD305PDB12 ELECTRIC OVEN
Whirlpool RBD305PDB13 ELECTRIC OVEN
Whirlpool RBD305PDB14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDB2 ELECTRIC OVEN
Whirlpool RBD305PDB3 ELECTRIC OVEN
Whirlpool RBD305PDB4 ELECTRIC OVEN
Whirlpool RBD305PDB6 ELECTRIC OVEN
Whirlpool RBD305PDB7 ELECTRIC OVEN
Whirlpool RBD305PDB8 ELECTRIC OVEN
Whirlpool RBD305PDB9 ELECTRIC OVEN
Whirlpool RBD305PDQ1 ELECTRIC OVEN
Whirlpool RBD305PDQ10 ELECTRIC OVEN
Whirlpool RBD305PDQ11 ELECTRIC OVEN
Whirlpool RBD305PDQ12 ELECTRIC OVEN
Whirlpool RBD305PDQ13 ELECTRIC OVEN
Whirlpool RBD305PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ2 ELECTRIC OVEN
Whirlpool RBD305PDQ3 ELECTRIC OVEN
Whirlpool RBD305PDQ4 ELECTRIC OVEN
Whirlpool RBD305PDQ6 ELECTRIC OVEN
Whirlpool RBD305PDQ7 ELECTRIC OVEN
Whirlpool RBD305PDQ8 ELECTRIC OVEN
Whirlpool RBD305PDQ9 ELECTRIC OVEN
Whirlpool RBD305PDS12 ELECTRIC OVEN
Whirlpool RBD305PDS14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDS15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT11 ELECTRIC OVEN
Whirlpool RBD305PDT12 ELECTRIC OVEN
Whirlpool RBD305PDT13 ELECTRIC OVEN
Whirlpool RBD305PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB1 Built-In Oven, Electric
Whirlpool RBD306PDB10 OVEN
Whirlpool RBD306PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB12 OVEN
Whirlpool RBD306PDB13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB2 Built-In Oven, Electric
Whirlpool RBD306PDB4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDB8 ELECTRIC WALL OVEN
Whirlpool RBD306PDB9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ1 Built-In Oven, Electric
Whirlpool RBD306PDQ10 OVEN
Whirlpool RBD306PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ12 OVEN
Whirlpool RBD306PDQ13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ2 Built-In Oven, Electric
Whirlpool RBD306PDQ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDQ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDT11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT12 OVEN
Whirlpool RBD306PDT13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDZ1 30" BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ10 OVEN
Whirlpool RBD306PDZ2 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDZ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD307PDB1 ELECTRIC OVEN
Whirlpool RBD307PDB2 ELECTRIC OVEN
Whirlpool RBD307PDQ1 ELECTRIC OVEN
Whirlpool RBD307PDQ2 ELECTRIC OVEN
Whirlpool RBD307PDQ4 ELECTRIC OVEN
Whirlpool RBD307PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVS03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Maytag RBE170PA REF - TOP MOUNT
Maytag RBE170PW REF - TOP MOUNT
Maytag RBE170TA REF - TOP MOUNT
Maytag RBE170TM REF - TOP MOUNT
Maytag RBE170TV REF - TOP MOUNT
Maytag RBE170TW REF - TOP MOUNT
Maytag RBE17KA-0A REF - TOP MOUNT
Maytag RBE17KN-0A REF - TOP MOUNT
Maytag RBE193PA REF - TOP MOUNT
Maytag RBE193PW REF - TOP MOUNT
Maytag RBE193TA REF - TOP MOUNT
Maytag RBE193TM REF - TOP MOUNT
Maytag RBE193TV REF - TOP MOUNT
Maytag RBE193TW REF - TOP MOUNT
Maytag RBE19KA-3A REF - TOP MOUNT
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Control Board Doug Long Oven Repair (including Ranges and Cooktops) 1 01-17-2012 08:25 AM
no oven new control board rlcjmrdr Oven Repair (including Ranges and Cooktops) 1 01-10-2012 05:54 PM
Oven Control Board JOHN SHEPHERD Oven Repair (including Ranges and Cooktops) 0 07-16-2011 06:06 PM
Kenmore Built In Oven Control Panel And Oven Control Board. TDEUCEDOG06 Oven Repair (including Ranges and Cooktops) 0 06-01-2010 03:28 PM
oven control board Quisty2 Oven Repair (including Ranges and Cooktops) 1 02-16-2009 06:16 PM
