Discuss
Ovens top bake element will come on and heat up but the bottom one will not
 in
The oven never really heated quite right, I would always have to set the bake temp 25-30 degrees higher than
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Ovens top bake element will come on and heat up but the bottom one will not
  #1 (permalink)
Old 05-23-2013, 07:14 PM
Junior Member
ah1988 is on a distinguished road
Default Ovens top bake element will come on and heat up but the bottom one will not
Model Number: 4GR450LXHB   Brand: Whirlpool   Age: More than 10 years
The oven never really heated quite right, I would always have to set the bake temp 25-30 degrees higher than reccomended for it to heat up hot enough. The bottom bake element will not come on at all but the top one comes on but it dosent see to get as hot as it should. I tested to see if the bottom element was burnt out with a ohm meter and it tested 20ohms so it seems to be good. I tested to see if I was getting voltage to the bottom element and I was not. I turned the oven on and set it to 350deg. bake and tested to see if I had any voltage to the two wires that connect to the back of the element and I did not. I did a little research and I found that the temp sensor probe may be burtn out but it tested out fine at 1080ohms.
What is my next step I am now out of ideas and I am not finding anything new through research ?
It is a electric oven.
If you suggest a part, if you could please tell me the location and how to test it that would be greatly appreciated... I am no pro.
Related Models
Whirlpool 4K45SS MIXER
Whirlpool 4K45SS7OB0 4 1/2 QT. STAND MIXER
Whirlpool 4K45SS7WH0 4 1/2 QT. STAND MIXER
Whirlpool 4K45SSDWH-1 4 1/2 QT. STAND MIXER
Whirlpool 4K45SSWH-1 4 1/2 QT. STAND MIXER
Whirlpool 4K5SS MIXER
Whirlpool 4K5SSOB0 5 QT. CLASSIC STAND MIXER CANADIAN - LIFT
Whirlpool 4K5SSWH1 5 QT. CLASSIC STAND MIXER CANADIAN - LIFT
Maytag 4KAED4475TQ0 29" ELECTRIC DRYER
Maytag 4KATW4605TQ0 AUTOMATIC WASHER
Whirlpool 4KB25G1XBU3 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
Whirlpool 4KB25G1XBU5 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
KitchenAid 4KB25G1XBY5 5 QT. STAND MIXER / DELUXE EDITION
KitchenAid 4KB25G1XCO5 5 QT. STAND MIXER / DELUXE EDITION
Whirlpool 4KB25G1XER3 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
Whirlpool 4KB25G1XER5 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
KitchenAid 4KB25G1XGA5 5 QT. STAND MIXER / DELUXE EDITION
Whirlpool 4KB25G1XMC5 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
KitchenAid 4KB25G1XMY5 5 QT. STAND MIXER / DELUXE EDITION
Whirlpool 4KB25G1XOB3 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
Whirlpool 4KB25G1XOB5 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
Whirlpool 4KB25G1XTG3 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
Whirlpool 4KB25G1XTG5 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
Whirlpool 4KB25G1XWW3 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
Whirlpool 4KB25G1XWW5 5 QT. STAND MIXER DELUXE EDITION BOWL LIFT
Whirlpool 4KBDS250S0 DISPOSER
Whirlpool 4KBDS250T1 DISPOSER
Whirlpool 4KBDS250T4 DISPOSER
Whirlpool 4KBDS250T5 DISPOSER
Whirlpool 4KCDS250S0 DISPOSER
Whirlpool 4KCDS250T1 DISPOSER
Whirlpool 4KCDS250T2 DISPOSER
Whirlpool 4KCG200BU0 COFFEE MILL
Whirlpool 4KCG200BU1 COFFEE MILL
Whirlpool 4KCG200ER0 COFFEE MILL
Whirlpool 4KCG200ER1 COFFEE MILL
Whirlpool 4KCG200MC0 COFFEE MILL
Whirlpool 4KCG200MC1 COFFEE MILL
Whirlpool 4KCG200OB0 COFFEE MILL
Whirlpool 4KCG200OB1 COFFEE MILL
Whirlpool 4KCG200PK0 COFFEE MILL
Whirlpool 4KCG200PK1 COFFEE MILL
Whirlpool 4KCG200WH0 COFFEE MILL
Whirlpool 4KCG200WH1 COFFEE MILL
Whirlpool 4KD2661XMC3 6 QT. STAND MIXER CUSTOM BOWL LIFT
Whirlpool 4KFC3100BU2 3 CUP FOOD CHOPPER
Whirlpool 4KFC3100CR2 3 CUP FOOD CHOPPER
Whirlpool 4KFC3100ER2 3 CUP FOOD CHOPPER
Whirlpool 4KFC3100OB2 3 CUP FOOD CHOPPER
Whirlpool 4KFC3100WH2 3 CUP FOOD CHOPPER
Whirlpool 4KFP710WH0 FOOD PROCESSOR 7 Cup
Whirlpool 4KFP710WH1 7-CUP FOOD PROCESSOR
Whirlpool 4KFP710WH2 7-CUP FOOD PROCESSOR
Whirlpool 4KFP720BU0 FOOD PROCESSOR 7 Cup
Whirlpool 4KFP720BU1 7-CUP FOOD PROCESSOR
Whirlpool 4KFP720BU2 7-CUP FOOD PROCESSOR
Whirlpool 4KFP720ER0 FOOD PROCESSOR 7 Cup
Whirlpool 4KFP720ER1 7-CUP FOOD PROCESSOR
Whirlpool 4KFP720ER2 7-CUP FOOD PROCESSOR
Whirlpool 4KFP720OB0 FOOD PROCESSOR 7 Cup
Whirlpool 4KFP720OB1 7-CUP FOOD PROCESSOR
Whirlpool 4KFP720OB2 7-CUP FOOD PROCESSOR
Whirlpool 4KFP720WH0 FOOD PROCESSOR 7 Cup
Whirlpool 4KFP720WH1 7-CUP FOOD PROCESSOR
Whirlpool 4KFP720WH2 7-CUP FOOD PROCESSOR
Whirlpool 4KFP730WH0 7-CUP FOOD PROCESSOR
Whirlpool 4KFP730WH1 7-CUP FOOD PROCESSOR
Whirlpool 4KFP730WH2 7-CUP FOOD PROCESSOR
Whirlpool 4KFP740CR0 9-CUP FOOD PROCESSOR
Whirlpool 4KFP740WH0 9-CUP FOOD PROCESSOR
Whirlpool 4KFP740WH1 9-CUP FOOD PROCESSOR
Whirlpool 4KFP750BU0 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750BU1 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750CR0 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750ER0 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750ER1 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750OB0 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750OB1 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750PK0 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750PK1 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750WH0 12-CUP FOOD PROCESSOR
Whirlpool 4KFP750WH1 12-CUP FOOD PROCESSOR
Whirlpool 4KFPM770CR0 FOOD PROCESSOR 12 Cup (Wide Mouth)
Whirlpool 4KFPM770NK0 FOOD PROCESSOR
Whirlpool 4KFPM770NK1 MIDLINE FOOD PROCESSOR
Whirlpool 4KFPM770NK2 MIDLINE FOOD PROCESSOR 12 CUP - WIDE MOUTH/METALLIC
Whirlpool 4KFPW760OB0 FOOD PROCESSOR
Whirlpool 4KFPW760OB1 FOOD PROCESSOR
Whirlpool 4KFPW760OB2 MIDLINE FOOD PROCESSOR
Whirlpool 4KFPW760OB3 MIDLINE FOOD PROCESSOR 12 CUP - WIDE MOUTH
Whirlpool 4KFPW760WH0 FOOD PROCESSOR
Whirlpool 4KFPW760WH1 FOOD PROCESSOR
Whirlpool 4KFPW760WH2 MIDLINE FOOD PROCESSOR
Whirlpool 4KFPW760WH3 MIDLINE FOOD PROCESSOR 12 CUP - WIDE MOUTH
Whirlpool 4KFRF19MTA00
Whirlpool 4KFRF19MTP00
Whirlpool 4KFRF19MTT00
Whirlpool 4KFRF19MTW00
Whirlpool 4KG25G0XMC4 5 QT. STAND MIXER
Whirlpool 4KG25G0XWH4 5 QT. STAND MIXER
Whirlpool 4KG25G7XER4 5 QT. STAND MIXER
Whirlpool 4KG25G7XOB4 5 QT. STAND MIXER
Whirlpool 4KG25G7XSL4 5 QT. STAND MIXER
Whirlpool 4KG25G7XWH4 5 QT. STAND MIXER
Whirlpool 4KG25H3XER5 5 QT. STAND MIXER PROFESSIONAL HEAVY DUTY BOWL LIFT
Whirlpool 4KG25H3XOB5 5 QT. STAND MIXER PROFESSIONAL HEAVY DUTY BOWL LIFT
Whirlpool 4KG25H3XSL5 5 QT. STAND MIXER PROFESSIONAL HEAVY DUTY BOWL LIFT
Whirlpool 4KG25H3XWH5 5 QT. STAND MIXER PROFESSIONAL HEAVY DUTY BOWL LIFT
Whirlpool 4KHM3WH5 3-SPEED HAND MIXER
Whirlpool 4KHM5DHWH5 5-SPEED HAND MIXER
Whirlpool 4KHM5TBWH5 5-SPEED HAND MIXER
Whirlpool 4KHM7TAC5 7-SPEED HAND MIXER
Whirlpool 4KHM7TBU5 7-SPEED HAND MIXER
Whirlpool 4KHM7TER5 7-SPEED HAND MIXER
Whirlpool 4KHM7TGN5 7-SPEED HAND MIXER
Whirlpool 4KHM7TMY5 7-SPEED HAND MIXER
Whirlpool 4KHM7TOB5 7-SPEED HAND MIXER
Whirlpool 4KHM7TWH5 7-SPEED HAND MIXER
Maytag 4KHTW4505TQ0 AUTOMATIC WASHER
Whirlpool 4KHWS160AL8 WATER DISPENSER
  #2 (permalink)
Old 05-24-2013, 02:02 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I cannot find any info on the given model number.
Are you sure it has a 4 at the start of it.
Also is there a number at the end of it.
It does sound like your control board is toast.
When you try to use it does it stay in preheat or does the oven show ready?
If it stays in preheat then your oven sensor is probably OK.
If it shows ready it could be the oven sensor but could also be a bad control board.
__________________
  #3 (permalink)
Old 05-24-2013, 03:05 AM
Junior Member
Default
When I push the bake button and then hit start it shows "pre-heat", the top burner comes on but the bottom dosent. But when I push bake set the temp, push cook time and set the cook time then press start it dosent show pre-heat it just goes into bake mode. The pic of the controll board is when I do bake, cook time, then start.
I also have a pic of the model number.
  #4 (permalink)
Old 05-24-2013, 03:50 AM
Senior Expert
APP Volunteer
Default
See the attachment for the wiring diagram that comes up for the GR450LXHB series of units.
Usually when in bake or preheat the bake and broil elements switch back and forth.
This gives a quicker preheat and also provides a more even temperature profile in the oven.
It sounds like your control board is toast since the oven sensor, the bake element and power to the unit are all OK.
If you purchase it from AppliancePartsPros they will allow you to return it if it does not fix the problem. Please see their return policy.
As far as your other problem with having to set a higher temperature to get the oven to the correct temperature. This may have just needed a oven temperature calibration. Most units will let you calibrate plus or minus 30 degrees.
__________________
  #5 (permalink)
Old 05-24-2013, 03:44 PM
Junior Member
Default
is this the controll board ?
Whirlpool 9782087CB Electronic Range Clock(black) - AppliancePartsPros.com
  #6 (permalink)
Old 05-25-2013, 02:50 AM
Senior Expert
APP Volunteer
Default
Yes.
Be sure to have the model and serial numbers available as there may be different revisions of the board.
Also tell them about the problem we had with the model number even though the board you list does look like rge one in your unit.
There may be something that I am not aware of with theses model numbers.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replaced Bake element, now no heat from bake or broil adambmoose Oven Repair (including Ranges and Cooktops) 1 08-14-2012 03:11 AM
Bottom bake element not working oldmill Oven Repair (including Ranges and Cooktops) 6 06-05-2012 03:44 AM
Bottom bake element always ON milev_r Oven Repair (including Ranges and Cooktops) 5 10-17-2011 02:12 AM
Replace Bake Element, Remove Oven Bottom jcarbeck Oven Repair (including Ranges and Cooktops) 3 01-07-2010 12:53 AM
bottom bake element won't lite allen9258 Oven Repair (including Ranges and Cooktops) 0 05-12-2009 08:21 PM
