All burners stopped sparking so I installed a new spark module GE WB13K25 and I still get no sparking when I turn on any burner. I checked voltage at line in to module and needle barely moved on AC scale when I turn on gas to a burner to activate switch. No voltage with burners off.
I think trouble with the original spark module may have started after I used the self clean feature for the range, probably for the first time.
What is wrong and how do I troubleshoot?
