Discuss
error code 4 on ge stove j bp79g s1bb
 in
i first got error code f4 after oven was turned on and started heating up...replaced oven temp sensor as stated
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » error code 4 on ge stove j bp79g s1bb
  #1 (permalink)
Old 05-21-2013, 10:44 AM
Junior Member
lblackmon is on a distinguished road
Default error code 4 on ge stove j bp79g s1bb
Brand: GE   Age: 1 - 5 years
i first got error code f4 after oven was turned on and started heating up...replaced oven temp sensor as stated in troubleshooting guide..now as soon as i plug it up and start to increase oven temp. its starts to continously beep and shows error code f3...which is listed as oven temp probe...im lost
  #2 (permalink)
Old 05-21-2013, 02:50 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You need to check the connector plugs or the splicing (depends on what you have there) and wiring harness between the control and the sensor.
You may check the sensor's resistance at the control board disconnect plug.
At room temperature you should have about 1100 ohms.
In case if the resistance is correct the control board is defective. Unfortunately, it's no longer available.
Here are the breakdown diagrams and http://www.appliancepartspros.com/01...-jbp79gs1.html
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrolux/Frigidaire Stove Error code F1 stickyfingers Oven Repair (including Ranges and Cooktops) 0 12-27-2012 05:39 AM
Electrolux/Frigidaire Stove Error code F1 stickyfingers Oven Repair (including Ranges and Cooktops) 0 12-27-2012 05:24 AM
kenmore elite gas stove error code F11 dolesen Washer Repair 1 03-29-2012 03:47 PM
whirlpool gas stove wrong error code colusapaul Oven Repair (including Ranges and Cooktops) 5 12-06-2011 06:39 PM
F1 Error Code GE Gas STove LGStyle Oven Repair (including Ranges and Cooktops) 0 03-20-2011 11:18 AM
