awash
#1 Posted : Tuesday, October 6, 2009 3:11:44 PM(UTC)
awash
Kitchen Aid double oven door would not unlock after self cleaning. Sears service replaced Thermal sensor. Now oven will not heat. Sears wants to install new Control panel $465.00. Your service has this part on back order with no stock listed any time soon. Internet has this as a very common problem, but cannot find solution. Some sites state to replace thermal fuse,but your on line tech support says this model does not have a fuse. Can you offer some help? Thanks
#2 Posted : Wednesday, October 7, 2009 4:56:25 AM(UTC)
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%204451879.pdf
It does show a thermal cut off on both the upper and lower ovens.
Did it heat up after the sensor replacement?
Are both ovens not working?
If it never had heat again I would suspect the thermal cut off.
Here is a manual which may help
https://secured.whirlpoo...Double%20Wall%20Oven.pdf
awash
#3 Posted : Wednesday, October 7, 2009 11:59:53 AM(UTC)
awash
Do you think a "thermal Cut Off" can be replaced. Thank you for the service manual. The top oven works fine, but with the holidays coming I really need both ovens. Thanks
#4 Posted : Wednesday, October 7, 2009 3:06:54 PM(UTC)
Yes it can be replaced but first you have to find out if it is causing the problem.
awash
#5 Posted : Monday, October 12, 2009 5:31:28 PM(UTC)
awash
Thank you so much. Sears service replaced the Thermal control and I am up and cooking! Very helpful
