Discuss
Maytag Gemini Oven wont heat
 in
Sorry for the lack of model information. I can not seem to find a model number anywhere on the oven.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Gemini Oven wont heat
  #1 (permalink)
Old 05-15-2013, 05:12 PM
Junior Member
Stevewk is on a distinguished road
Default Maytag Gemini Oven wont heat
Model Number: ?   Brand: Maytag   Age: 5 - 10 years
Sorry for the lack of model information. I can not seem to find a model number anywhere on the oven. The Technical Information package I have from the back of the oven says t si good for the following models: MER6555AAB/Q/W, MER6775AAB/F/N/Q/S/W, MER6751AAB/Q/S/w or MER6755AAB/Q/S/W. http://forum.appliancepartspros.com/...s/confused.gif
It is an electric cooktop stove, all digital control panel (no knobs) with dual ovens.
Everything works fine with the exception of the upper oven. The broiler heating element works as expected (heats to a glowing red when turned on, etc.), but the upper oven will not heat up to temp.
I have ohmed out both heating elements and they both are within 5 ohms of each other (< 30 ohms). I have checked the temp sensor and it checks ok (about 880 ohms - same as the lower temp sensor so I assume it is ok since the lower oven works fine).
When I turn on the oven and measure the voltage, the upper heating element reads 110V from each lead to ground and 240 across each lead. When I make the same measurement on the lower heating element, I get the 110V from each lead to ground but Zero volts from lead to lead. Does this indicate a control panel issue or a problem with the heating element, even though the resistance check is ok?
Also, where can I find the exact model number of my unit?
Thanks for any help.
Steve
Related Models
General Electric A*B588D Room air conditioner
General Electric A*B588E Room air conditioner
General Electric A*B688D Room air conditioner
General Electric A*B688E Room air conditioner
Frigidaire A04LE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A04LE2F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2E1 Frg(v2) / Room Air Conditioner
Frigidaire A05LE2E2 Frg(v4) / Room Air Conditioner
Frigidaire A05LE2E3 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2E7 Frg(v1) / Room Air Conditioner
Frigidaire A05LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5F2 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5K1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH5N1 Frg(v0) / Room Air Conditioner
Frigidaire A05LH8F1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH8L1 Frg(v1) / Room Air Conditioner
Frigidaire A05LH8N1 Frg(v1) / Room Air Conditioner
Frigidaire A05LS1F1 Frg(v1) / Air Conditioner
Frigidaire A05LS1N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2E1 Frg(v3) / Room Air Conditioner
Frigidaire A06LE2E2 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2E3 Frg(v2) / Room Air Conditioner
Frigidaire A06LE2K1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LE3E1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5E2 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH5N1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH6F1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH6L1 Frg(v1) / Room Air Conditioner
Frigidaire A06LH8E1 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E1 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E2 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8E3 Frg(v1) / Room Air Conditioner
Frigidaire A07LH8L1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2E2 Frg(v2) / Room Air Conditioner
Frigidaire A08LE2N1 Frg(v1) / Room Air Conditioner
Frigidaire A08LE2N2 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5E1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5E2 Frg(v2) / Room Air Conditioner
Frigidaire A08LH5F1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L1 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L2 Frg(v1) / Room Air Conditioner
Frigidaire A08LH5L3 Frg(v1) / Room Air Conditioner
Frigidaire A08LH8N1 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E1 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E2 Frg(v2) / Room Air Conditioner
Frigidaire A08ME2E3 Frg(v1) / Room Air Conditioner
Frigidaire A08ME2E4 Frg(v1) / Room Air Conditioner
Whirlpool A0W23W10 Air-conditioner/heat pump
Jenn-Air A100 ELE CARTRIDGE
Jenn-Air A100-8 ELE CARTRIDGE
Jenn-Air A100-C ELE CARTRIDGE
Jenn-Air A100B ELE CARTRIDGE
Jenn-Air A100B-8 ELE CARTRIDGE
Jenn-Air A100B-C ELE CARTRIDGE
Jenn-Air A100L ELE CARTRIDGE
Jenn-Air A100L-C ELE CARTRIDGE
Maytag A100S WASHER-TOP LOADING
Jenn-Air A100S-8 ELE CARTRIDGE
Jenn-Air A100W ELE CARTRIDGE
Jenn-Air A100W-8 ELE CARTRIDGE
Jenn-Air A100W-C ELE CARTRIDGE
Maytag A101 WASHER-TOP LOADING
Maytag A102 WASHER-TOP LOADING
Maytag A102S WASHER-TOP LOADING
Maytag A103 WASHER-TOP LOADING
Maytag A103S WASHER-TOP LOADING
Maytag A104 WASHER-TOP LOADING
Maytag A105 WASHER-TOP LOADING
Jenn-Air A105-8 MISC / ACCESSORY
Jenn-Air A105W-8 MISC / ACCESSORY
Maytag A106 WASHER-TOP LOADING
Jenn-Air A106B ELE CARTRIDGE
Maytag A106S WASHER-TOP LOADING
Jenn-Air A106W ELE CARTRIDGE
Maytag A107 WASHER-TOP LOADING
Maytag A107S WASHER-TOP LOADING
Maytag A108 WASHER-TOP LOADING
Hoover A1089
Maytag A108S WASHER-TOP LOADING
Maytag A110 WASHER-TOP LOADING
Jenn-Air A110-8 MISC / ACCESSORY
Admiral A1100PRA RANGE- F/S STD GAS
Admiral A1100PRA-K RANGE- F/S STD GAS
Admiral A1100PRW RANGE- F/S STD GAS
Admiral A1100PRW-K RANGE- F/S STD GAS
Jenn-Air A111 MISC / ACCESSORY
Jenn-Air A111-8 MISC / ACCESSORY
Maytag A112 WASHER-TOP LOADING
Frigidaire A11ME5E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5F1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5L2 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E2 Frg(v2) / Room Air Conditioner
Frigidaire A11ME8E3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDC2 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDSD3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDTC2 Frg(v2) / Room Air Conditioner
Frigidaire A11MEUC2 Frg(v3) / Room Air Conditioner
Frigidaire A11MEUSD2 Frg(v2) / Room Air Conditioner
Frigidaire A11MEUTSD2 Frg(v3) / Room Air Conditioner
Jenn-Air A120 MISC / ACCESSORY
Jenn-Air A120-8 MISC / ACCESSORY
Amana A1200S COMMERCIAL MICROWAVES
Jenn-Air A121B ELE CARTRIDGE
Jenn-Air A121B-8 ELE CARTRIDGE
Jenn-Air A121W ELE CARTRIDGE
Jenn-Air A121W-8 ELE CARTRIDGE
Amana A1225S COMMERCIAL MICROWAVES
Jenn-Air A122B ELE CARTRIDGE
Maytag A122B14 RADIANT ELEMENT CARTRIDGE
Jenn-Air A122W ELE CARTRIDGE
  #2 (permalink)
Old 05-16-2013, 04:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Steve,
The model number can be found on a metal tag located on the back of the control panel. Reach behind the top left corner of the control panel and rotate the tags up to view the data.
In order to provide most accurate advice we need the complete model number of the range.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Gemini double oven kdskattum@gmail.com Oven Repair (including Ranges and Cooktops) 1 03-14-2013 03:10 AM
Maytag Gemini double oven bobmullen364 Oven Repair (including Ranges and Cooktops) 5 01-07-2012 10:16 AM
Maytag gemini oven wendieww Oven Repair (including Ranges and Cooktops) 1 12-01-2010 07:06 AM
maytag oven wont heat up Dan-o Oven Repair (including Ranges and Cooktops) 1 03-30-2010 09:16 AM
Maytag Gemini Oven ekuntz Oven Repair (including Ranges and Cooktops) 1 01-02-2010 08:20 AM
