Maytag oven wont work. Stove top works fine. Oven and broiler wont.
Is there a way to check for an error code or any common faults with these?
Thanks.
Groups: APP Team
Hi. Most likely you have the open hi-limit switch. It's resettable and located at the rear of the range.Remove lower rear access panel to get to it. Use a multimeter to check switch for continuity. In case if it won't reset get a new one Part number: 74008715
That worked!!! Awesome thanks!!! Second pizza cooking now lol
Groups: APP Team
You are welcome.
Can I have a slice?:)
Simon.
