Discuss
Jenn-Air Double Oven Problems
 in
Hello, Thanks for the help upfront. I have a Jenn-Air double oven with several issues. First the broiler element wasn't
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Double Oven Problems
  #1 (permalink)
Old 05-14-2013, 08:38 PM
Junior Member
goatguns is on a distinguished road
Default Jenn-Air Double Oven Problems
Model Number: WW27430B   Brand: Jenn-Air   Age: More than 10 years
Hello,
Thanks for the help upfront. I have a Jenn-Air double oven with several issues. First the broiler element wasn't working in the top so I swapped it with the bottom element since it never got used. The bottom oven had an Fr error code before I swapped elements. The broiler still didn't work in the top unit. I replaced the upper AND lower relay board, the oven control board, checked the oven temp sensors (checked ok). Now when I turned the power on I get an F1 error code which should be the oven control board but I just replaced it. I am stumped. HELP!
Jenn-Air WW27430B
Related Models
Jenn-Air WW27430B WALLOVEN- S/C ELE
Jenn-Air WW27430BC WALLOVEN- S/C ELE
Jenn-Air WW27430P WALLOVEN- S/C ELE
Jenn-Air WW27430PF WALLOVEN- S/C ELE
Jenn-Air WW27430PG WALLOVEN- S/C ELE
Jenn-Air WW27430PK WALLOVEN- S/C ELE
Jenn-Air WW27430PR WALLOVEN- S/C ELE
Jenn-Air WW27430PU WALLOVEN- S/C ELE
Jenn-Air WW27430W WALLOVEN- S/C ELE
Jenn-Air WW27430WC WALLOVEN- S/C ELE
Jenn-Air WW2750B WALLOVEN- S/C ELE
Jenn-Air WW2750W WALLOVEN- S/C ELE
Jenn-Air WW2780B WALLOVEN- S/C ELE
Jenn-Air WW2780B-C WALLOVEN- S/C ELE
Jenn-Air WW2780W WALLOVEN- S/C ELE
Jenn-Air WW2780W-C WALLOVEN- S/C ELE
Whirlpool WW29000SU0 LAUNDRY WORKSURFACE
Whirlpool WW29000SW0 LAUNDRY WORKSURFACE
Jenn-Air WW30110B WALLOVEN- S/C ELE
Jenn-Air WW30110W WALLOVEN- S/C ELE
Jenn-Air WW30430B WALLOVEN- S/C ELE
Jenn-Air WW30430P WALLOVEN- S/C ELE
Jenn-Air WW30430PC WALLOVEN- S/C ELE
Jenn-Air WW30430PF WALLOVEN- S/C ELE
Jenn-Air WW30430PG WALLOVEN- S/C ELE
Jenn-Air WW30430PK WALLOVEN- S/C ELE
Jenn-Air WW30430PR WALLOVEN- S/C ELE
Jenn-Air WW30430PU WALLOVEN- S/C ELE
Jenn-Air WW30430W WALLOVEN- S/C ELE
Frigidaire WW334AGW0 Wwh(v1) / Washer
Frigidaire WW334AGW1 Wwh(v2) / Washer
Frigidaire WW334AGW2 Wwh(v3) / Washer
 WW600 MWAVE- CNTRTP / STAND ALONE
General Electric WW8318LAL AUTOMATIC WASHER
General Electric WWA3100BAL Washer
General Electric WWA3100GAL Washer
General Electric WWA3100GBL Washer
General Electric WWA3100VCL Washer
General Electric WWA3650MAL Washer
General Electric WWA3650RBL Washer
General Electric WWA3650SALAD Washer
General Electric WWA3650SALHA Washer
General Electric WWA3650SALWH Washer
General Electric WWA3657SALHA Washer
General Electric WWA3657SALWH Washer
General Electric WWA5009VCL Washer
General Electric WWA5304VNL Washer
General Electric WWA5304VPL Washer
General Electric WWA5400SALWH Washer
General Electric WWA5400SBLWH Washer
General Electric WWA5407MAL Washer
General Electric WWA5411BAL Washer
General Electric WWA5411GAL Washer
General Electric WWA5411VEL Washer
General Electric WWA5412BAL Washer
General Electric WWA5412GAL Washer
General Electric WWA5412VEL Washer
General Electric WWA5509VCL Washer
General Electric WWA5600BAL Washer
General Electric WWA5600GAL Washer
General Electric WWA5600GBL Washer
General Electric WWA5600RBL Washer
General Electric WWA5600SALAA Washer
General Electric WWA5600SALHA Washer
General Electric WWA5600SALWW Washer
General Electric WWA5600SBLAA Washer
General Electric WWA5600SBLWW Washer
General Electric WWA5600VCL Washer
General Electric WWA5610BAL Washer
General Electric WWA5636MAL Washer
General Electric WWA5669MAL Washer
General Electric WWA5669MBL Washer
General Electric WWA5710MAL Washer
General Electric WWA5710RBL Washer
General Electric WWA5710SALAA Washer
General Electric WWA5710SALWW Washer
General Electric WWA5710SBLAA Washer
General Electric WWA5710SBLWW Washer
General Electric WWA5800BAL Washer
General Electric WWA5800GAL Washer
General Electric WWA5800GBL Washer
General Electric WWA5800MAL Washer
General Electric WWA5800RBL Washer
General Electric WWA5800VCL Washer
General Electric WWA5809RBL Washer
General Electric WWA5826MAL Washer
General Electric WWA5826RBL Washer
General Electric WWA5857RBL Washer
General Electric WWA6007MAL Washer
General Electric WWA6407LBL Washer
General Electric WWA6600MAL Washer
General Electric WWA6600RBL Washer
General Electric WWA6600SALAA Washer
General Electric WWA6600SALWW Washer
General Electric WWA6600SBLAA Washer
General Electric WWA6600SBLWW Washer
General Electric WWA6800SALAD Washer
General Electric WWA6800SALHA Washer
General Electric WWA6800SALWH Washer
General Electric WWA7010GAL Washer
General Electric WWA7010GBL Washer
General Electric WWA7050BAL Washer
General Electric WWA7050GAL Washer
General Electric WWA7050GBL Washer
General Electric WWA7059VCL Washer
General Electric WWA7060VCL Washer
General Electric WWA7070BAL Washer
General Electric WWA7070GAL Washer
General Electric WWA7070GBL Washer
General Electric WWA7070VCL Washer
General Electric WWA7079VCL Washer
General Electric WWA7304PML Washer
General Electric WWA7304VKL Washer
General Electric WWA7304VLL Washer
General Electric WWA7600RBL Washer
General Electric WWA7600SALAA Washer
General Electric WWA7600SALWW Washer
General Electric WWA7600SBLAA Washer
General Electric WWA7600SBLWW Washer
General Electric WWA7619MAL Washer
  #2 (permalink)
Old 05-15-2013, 05:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
The "F1" error code means "Power to element relay energized during time of day display". The problem can be a shorted J2 harness between the control board and the lower oven relay board. The harness coming together with the new relay board.
You said that you already replaced the relay board. What is the part number of the new board and when and where did you buy it?
Here are the breakdown diagrams and Parts for Jenn-Air WW27430B Wall Oven - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-15-2013, 06:43 PM
Junior Member
Default
Part# AP4098257 less than a week ago from AppliancePartsPros.
  #4 (permalink)
Old 05-15-2013, 06:47 PM
Junior Member
Default
The Lower Relay #12001914 was purchased less than a week ago from Universal Appliance Parts.
  #5 (permalink)
Old 05-16-2013, 02:17 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Have you installed the lower relay board together with the new harness?
__________________
  #6 (permalink)
Old 05-16-2013, 06:56 PM
Junior Member
Default
Yes, along with the upper relay board and the oven control board.
  #7 (permalink)
Old 05-17-2013, 09:39 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Goatguns, You've probably already done this but, re check the J2 harness between the ERC/Clock and upper oven relay board. Re check the J7 harness, between the upper and lower oven relay boards and all the connections you made when replacing the parts.
On this style wall oven, a faulty membrane switch
Part number: AP4088611
can also create an F1 error code. Since it's not available, you can try to clean the ribbon connector insertion end and the ribbon connector on the control, with some electronic contact cleaner or rubbing alcohol. Good Luck
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help for Jenn Air double oven!! jennairhelp Oven Repair (including Ranges and Cooktops) 1 12-14-2012 05:18 PM
Jenn Air double wall oven problems jetdoc Oven Repair (including Ranges and Cooktops) 7 09-18-2012 10:14 AM
Help With Jenn Air Double OVen klsana00 Oven Repair (including Ranges and Cooktops) 0 02-27-2011 01:56 PM
Jenn Air Double Oven barrymick Oven Repair (including Ranges and Cooktops) 0 08-16-2010 06:54 PM
problems with double oven lsett Oven Repair (including Ranges and Cooktops) 1 11-05-2008 05:14 PM
