I installed a new baking element and the oven starts heating up without turning the oven to bake. I installed another element and it doesnt heat up at all. Tried a third element and it started heating up again. What is the next part I need to change out? Please help my wife is almost ready to kill me!:)
Pull the range out of the wall, remove the rear panel and check for a crossed wires from the control board to the heating elements. Fix if any found then check again. Remove the wires from the Baking heating element and check for 120 VAC between them with the control does not call for Bake. Replace the control board (aka a clock/timer) if there is power. - The clock Part number: AP3672811
