Discuss
Electric Control Panel Not Lit - no ability to use oven
 in
The electronic control panel has no lights, no clock, no ability to set temperature,etc. So basically the oven is not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric Control Panel Not Lit - no ability to use oven
  #1 (permalink)
Old 05-10-2013, 01:06 PM
Junior Member
Ladona is on a distinguished road
Default Electric Control Panel Not Lit - no ability to use oven
Model Number: ARR630   Brand: Amana   Age: More than 10 years
The electronic control panel has no lights, no clock, no ability to set temperature,etc. So basically the oven is not working.
There were no symptoms prior.
The stove top is working fine.
We pulled the back off to make sure there weren't any loose wires, which we didn't find. I can't find any schematics on line that are in anyway helpful. Any ideas?
Related Models
Amana ARR630 RANGE- S/C S/I DDRAFT GAS
Amana ARR630 RANGE- S/C S/I DDRAFT ELE
Amana ARR6300LL RANGE- S/C S/I DDRAFT ELE
Amana ARR6300W RANGE- S/C S/I DDRAFT ELE
Amana ARR6300WW RANGE- S/C S/I DDRAFT ELE
Amana ARR630L RANGE- S/C S/I DDRAFT ELE
Amana ARR630L1 RANGE- S/C S/I DDRAFT ELE
Amana ARR630LL RANGE- S/C S/I DDRAFT ELE
Amana ARR630W RANGE- S/C S/I DDRAFT ELE
Amana ARR630W1 RANGE- S/C S/I DDRAFT ELE
Amana ARR630WW RANGE- S/C S/I DDRAFT ELE
Amana ARR632E RANGE- S/C S/I DDRAFT ELE
Amana ARR632WW RANGE- S/C S/I DDRAFT ELE
Amana ARR633E RANGE- S/C S/I DDRAFT ELE
Amana ARR633W RANGE- S/C S/I DDRAFT ELE
Amana ARR633WW RANGE- S/C S/I DDRAFT ELE
Amana ARR6400L RANGE- S/C S/I DDRAFT ELE
Amana ARR6400L RANGE- S/C S/I DDRAFT GAS
Amana ARR6400LL RANGE- S/C S/I DDRAFT ELE
Amana ARR6400LL RANGE- S/C S/I DDRAFT GAS
Amana ARR6400W RANGE- S/C S/I DDRAFT ELE
Amana ARR6400W RANGE- S/C S/I DDRAFT GAS
Amana ARR6400WW RANGE- S/C S/I DDRAFT ELE
Amana ARR6400WW RANGE- S/C S/I DDRAFT GAS
Amana ARR6420CC RANGE- S/C S/I DDRAFT GAS
Amana ARR6420WW RANGE- S/C S/I DDRAFT GAS
Amana ARRS6500E Range - S/c S/i Ddraft Gas
Amana ARRS6500LL Range - S/c S/i Ddraft Gas
Amana ARRS6500WW Range - S/c S/i Ddraft Gas
Amana ARRS6550E RANGE- S/C S/I DDRAFT GAS
Amana ARRS6550LL RANGE- S/C S/I DDRAFT GAS
Amana ARRS6550WW RANGE- S/C S/I DDRAFT GAS
Amana ARS14 MISC / ACCESSORY
Amana ARS14L MISC / ACCESSORY
Amana ARS15 MISC / ACCESSORY
Amana ARS15L MISC / ACCESSORY
General Electric ARS18DAV1 Room air conditioner
General Electric ARS18DBV1 Room air conditioner
General Electric ARS18DBV2 Room air conditioner
Amana ARS2304AB REF - SXS/I&W
Amana ARS2304AC REF - SXS/I&W
Amana ARS2304AW REF - SXS/I&W
Amana ARS2364AB REF - SXS/I&W
Amana ARS2364AC REF - SXS/I&W
Amana ARS2364AW REF - SXS/I&W
Amana ARS2365AB REF - SXS/I&W
  #2 (permalink)
Old 05-11-2013, 07:02 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Does the oven light work?
If not then it may be a power problem.
If yes then odds are that the control board/timer is taost.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana electric oven control panel media440 Oven Repair (including Ranges and Cooktops) 0 09-25-2011 03:29 PM
Kitchenaid Electric/Microwave Oven Control Panel Replacement ckumpa Oven Repair (including Ranges and Cooktops) 3 08-14-2009 08:31 AM
Oven Electric Control panel is off moe torabi Oven Repair (including Ranges and Cooktops) 2 04-04-2009 12:52 PM
Electric oven control panel removal stpedson Oven Repair (including Ranges and Cooktops) 1 03-14-2009 08:53 PM
Everything on oven works except electric control panel Theredman Oven Repair (including Ranges and Cooktops) 3 01-05-2009 04:16 AM
