I have a Jenn-Air oven Model No. JGS8750ADW. The curved outside glass has become detached. The glass was attached to 4 sliding brackets that permitted it to float as it got hot. It looks like the glass was attached to the brackets with some dark grey epoxy. Does anyone know where I can get the right glue to repair this.
William
I called up the Dow Corning Corp. this morning. They recommended I use Dow Corning 736 Heat Resistant Sealant.
William
