LeesaBennett
#1 Posted : Wednesday, May 8, 2013 11:43:54 AM(UTC)
LeesaBennett
I just replaced the ignitor in the oven and it worked, but the oven got to about 500 degrees and would not shut off. Could I have shorted the gas valve?
Simon / APP Team
#2 Posted : Wednesday, May 8, 2013 2:50:28 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Leesa.
Most likely it's not a gas valve. To provide you with more assistance we need the complete model number of the unit.
Simon.
LeesaBennett
#3 Posted : Wednesday, May 8, 2013 3:54:41 PM(UTC)
LeesaBennett
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi, Leesa.
Simon.
The model number is JGBT32GEL2WH
LeesaBennett
#4 Posted : Wednesday, May 8, 2013 3:56:23 PM(UTC)
LeesaBennett
Hi, Leesa.
Simon.
Thermostat? Wired wrong?
LeesaBennett
#5 Posted : Wednesday, May 8, 2013 4:22:52 PM(UTC)
LeesaBennett
Sorry that model # is JGBP32GEL2WH
Simon / APP Team
#6 Posted : Wednesday, May 8, 2013 5:09:32 PM(UTC)
Simon / APP Team
Groups: APP Team
You need to check if the ignitor wires insulation is not damaged and bare wires not touching the cabinet. Then check the ignitor connector plug. If you have a multimeter then check the oven sensor resistance. At room temperature you should have about 1100 ohms. If all of this checks OK, then most likely it's a defective control board. It looks like this part is no longer available.
Simon.
Oven over heating and locking door (Oven Repair (including Ranges and Cooktops))
by mfender 1/11/2013 9:47:23 AM(UTC)
oven over heating (Oven Repair (including Ranges and Cooktops))
by don_chan 1/5/2013 6:56:42 PM(UTC)
Oven over heating (Oven Repair (including Ranges and Cooktops))
by Bob Lewis 11/29/2012 10:03:32 AM(UTC)
by greghzl 4/26/2011 1:10:33 PM(UTC)
by pigg74 2/6/2008 6:17:14 PM(UTC)
